![]() Drives: 2018 camaro zl1 Join Date: Jan 2023
Can anyone recommend me brake pads better than OEMs for track day at the end of month. I ordered dtc 70 but it’s nationwide back order even though hawk said there was many in stock. My zl1 is not 1le btw
Super Stock
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
I believe EBC makes a blue stuff equivalent to DTC 70's. It's been a while since I looked into pads but at the end of it all I wound up landing right back on the OEM Ferodo DS pads. Of course I'm not tracking mine either so what I need is different than what you need.
2017 Red Hot ZL1 A10 - Apex ARC-8's, 305/ 325 PS4's, DSX 9.06 12% lower, Griptec 2.5 upper, NGK HR7 Ruthenium plugs, Nostrum 22+ injectors, XDI Goliath HPFP, Katech dual in tank low side pump, Katech oil pump, LME tensioner, DOD delete, LT1 big fuel cam, Jokerz ported blower, MPI lid, GMS hood extractor bracket, Soler ported 87mm (91mm eff) TB, Granatelli SS plug wires, Cordes LTR reservoir, DMS T-stat housing, 186* LS3 T-stat, Black Widow Angry Housewife/ Corsa NPP mufflers, Borla X pipe, BMR engine mounts, Banks iDash, Lithium Battery, AEM X- Series, HP Tuners, E85, 16.5 psi
723 HP/ 765 TQ |
See you at the Track!
Drives: 2022 Rapid Blue SS 1LE Join Date: Feb 2022
I have Ferodo 1.11 and love them. Great bite, street friendly, easy on rotors, and don't fade.
2022 M6 Rapid Blue 1SS 1LE PDR (Current)
2022 M6 Rapid Blue ZL1 (SOLD) |
#4 | |
![]() ![]() Drives: Chevrolet Camaro ZL1 1LE Join Date: Oct 2021
Otherwise, either the Ferodo or EBC will do as previously suggested. Ferodo pads are known for a more progressive bite. While EBC are known for strong initial bite. |
#5 | |
![]() ![]() ![]() ![]() ![]() Drives: 2023 CT5 Blackwing, 2025 C8 Z07 Join Date: Sep 2016
Agree with the above. Also, the OEM pads are Ferodo, so if you like the feel of those, you'll love the DSUNO or DS 1.11
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 2025 Hysteria Purple C8 Z07 |
| Tags |
| brake pads, brakes, help me i'm a noob, track, zl1 |
