Old 09-12-2024, 07:30 PM   #1
Jaspa57
Drives: 98 Trans AM
P0137 and P2096 permanent codes
Had CSP Kooks headers, high flow cats (front only) and Borla S type exhaust installed on my 2020 ZL1 convertible today. Now getting permanent codes P0137 and P2096??? Is it normal to get codes on these cars after an install like this and then have them fixed via a tune? Installer did mention he could hear a very faint exhaust leak with a stethoscope where the high flow cat clamped to the headers. Could this be the source of the codes? Car is less responsive now :(
Jaspa57 is offline   Reply With Quote
Old 09-13-2024, 01:17 AM   #2
GreyGhost702
Drives: 2019 Camaro 1SS1LE
Yes, and particularly since you're supercharged, adding long tubes without a tune will lean you out a bit. You don't want to be lean with FI. You should be able to get away with normal driving but your fuel trims are likely whack and I'd avoid WOT. Get it tuned, the light will turn off. Permanent codes are there forever as far as I know. Maybe a dealer can reset them? I haven't gotten that far in my tuning process to know for sure yet, I have some permanent codes as well. Not that they bother me, but for the sake of OCD it would be nice to get rid of them.
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane
7/26/2024 Tuning in progress
GreyGhost702 is offline   Reply With Quote
Old 09-13-2024, 06:43 AM   #3
s346k
s346k's Avatar
Drives: like an old lady
i believe a tech ii is the only way to remove permanent codes.
Old 09-13-2024, 01:56 PM   #4
GreyGhost702
Wonder if there is a GM tech that can be bribed with booze to do some house cleaning on my permanent codes
Old 09-13-2024, 02:12 PM   #5
SomeGeoffGuy
SomeGeoffGuy's Avatar
Drives: 2023 2SS Convertible
No tune with those mods? That is probably why it feels less responsive. Don't cheap on a tune!
-Geoff
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold!
'23 2SS Convertible -Same as above except orange.
SomeGeoffGuy is offline   Reply With Quote
Old 09-14-2024, 10:25 AM   #6
s346k
s346k's Avatar
perhaps. it is an undertaking to remove codes after the fact. you need a competent, capable and willing tuner with a lot of connections. i remember we had to go on a witch hunt for a specific beta version of hpt that (at the time) was a few updates old. it honestly was a real pain in the ass.
but at the end of the day my fbo ethanol car could be scanned and had 0 codes.
Old 09-15-2024, 04:50 PM   #7
GreyGhost702
Other than burning the eyes of a GM tech, which at this point my car will never see mechanic shop or dealer anyway, is there any reason we should care about stored permanent codes? Even if I sold the car as-is, and someone had the audacity to plug in a scanner before deciding to buy, they would only be met with my side-eye and a raised brow to the look of, you're really worried what codes are stored on this car my dude?
Old 09-15-2024, 07:17 PM   #8
s346k
s346k's Avatar
buyer in an emissions state is all i can think of and that's exactly why i cleared mine.
Old 09-18-2024, 03:54 PM   #9
Stlwaco
The Beaner
Drives: 19 camaro ss
After camming my car, but before my tuner could come out, I had to start my car so I could move it out of the garage. Was getting new windows in the garage. That start up left me with 4 permanent codes. After tuning they wouldn't go away. Had them for two years. finally installed a new PCM do to another issue. Factory programmed new PCM with GM scanner/laptop. Then uploaded my HP Tuners file. Permanent codes gone , as well as the issue that made me replace the PCM.
Stlwaco is offline   Reply With Quote
