![]() Drives: '23 1SS 1LE-Sharkskin M6 Join Date: Apr 2022
Quick ask about diff fluid
Wrong section to ask this, but you guys here are prompt and accurate. '23 SS 1LE 6 speed. Looking to change fluid this weekend, what differential oil are you guys using? Had the factory stuff changed at 600 miles, now pushing 11k on the clock. You guys sticking with the AC Delco stuff or upping your game with other brands?
I went with the AC delco and got a bottle pump kit, both from amazon
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
I use RP max gear 75-90, really doesn't matter though.
![]() Drives: 2018 Camaro SS A8 "Dark Knight" Join Date: Oct 2019
AC Delco
DARK KNIGHT
2018 SS A8 11.37 @ 121.01 GPI Tuned E85 Nitto tires Roto Fab CAI MSD intake |
Instagram: Sangstah
Stick with the OEM stuff, its fairly cheap on amazon.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 1SS 6spd Join Date: Jan 2011
+1 on the Royal Purple mostly because I was trying it in the gear box but eventually went back to OE there. Still got RP in diff, just don't change that as often.
#7 |
Thanks for the fast replies!!
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
i used torco last time i did it but usually oem fluids
#9 |
![]() Drives: 23 Zl1 Join Date: Apr 2019
Oem 88862624
#10 |
![]() Drives: 2023 Camaro ZL1 Join Date: Jan 2023
I went with Redline 75W90 GL-5 gear oil. I have used it on many cars including previous Camaro and vette. It is compatible with OEM 88862624.
https://www.redlineoil.com/75w90-gl-5-gear-oil
2023 Camaro ZL1 6MT Summit White
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
Make sure you get the correct pump kit for the correct lit type
<Insert Cars You Own Here>
#12 |
![]() Drives: 2SS M6 Hot Wheels #515 Join Date: May 2020
Had the "groan" noise, with original fluid, swapped diff fluid at that time less then 4k miles with another brand. Still had groan. Took to dealer once I saw it was issue and they put new recommended OEM fluid in. No more groan.
For this anyways I only use OEM diff fluid.
Rotofab, Soler 87mm ported TB, Kooks headers / green cats, MSD wires, flex fuel
Stock intake (no porting) and stock NPP exhaust. |
#13 | |
USCG Retired (MKC)
Drives: 2018 2SS 1LE Black Join Date: Aug 2018
As said, Redline, AMSOIL, M1, Royal Purple or what have you full synthetic for the win, and a lot less sulfur smell. |
#14 |
![]() Drives: 2023/2SS/1LE/RadiantRed/A10 Join Date: Jul 2022
And damn that shit stankypoo!
2023/2SS/1LE/Radiant-Red/A10/Sunroof/Copper-Free-Breaks/Navigation —— Order History: 6/17/22-1100, 3/7/23-3000, TPW-4/3/23, 4/4/23-3800, 4/8/23-Delivered
