See you at the Track!
Drives: 2022 Rapid Blue SS 1LE Join Date: Feb 2022
ZL1 vs SS 1LE on track
I am looking for opinions from people who have owned both SS 1LE and ZL1/ZL1 1LE. I currently have a ZL1 with 1LE aero and some suspension/power upgrades (see signature). I have been toying with the idea of selling the ZL1 and getting an SS 1LE to track instead. The ZL1 is an amazing car, but the SS 1LE is great too. If you have made the switch, What did you like/dislike? This car will get driven on the street, but 90% will be a track car.
2022 M6 Rapid Blue 1SS 1LE PDR (Current)
2022 M6 Rapid Blue ZL1 (SOLD) |
I've only ever heard of people downgrading their ZL1 to the SS 1LE for autocross because of the weight difference and the supercharger giving them little to no advantage. On a road course, +200 hp is pretty nice to have in the straights and out of turns.
However, this is just my 2 cents', I'm also very interested in expert opinions.
#3 | |
![]() ![]() Drives: 2021 2SS 1LE Join Date: Aug 2020
I can't speak about the ZL1 first-hand, but provided you drive on tracks that have some long straights, I think you will miss the power difference. I myself would not (I chose to "live with" 460 HP/torque) as my focus for track is the corners. But based on the power you've added to your ZL1, I'm guessing you are a HP kind of guy and would miss the 300 HP difference between what you are running now and what the LT1 in the SS can offer.
Sure, you can try to add back a bunch of that power into the LT1, but you'll run the risk of sacrificing reliability, especially if you track it at sustained high rpm. |
#5 | |
![]() ![]() Drives: Chevrolet Camaro ZL1 1LE Join Date: Oct 2021
For outright cornering and handling, ZL1-1LE > SS (1LE). Maybe not Earth shatteringly better, but it certainly is better in nearly every category with the exception of conservation of consumables (brakes, pads, oils, control arms, etc.). |
#6 | |
![]() ![]() Drives: 2020 SS 1LE Join Date: Aug 2020
#7 | |
This will 90% be a track car, so I will probably add better aero and suspension down the line. I was also planning to get ZL1 front fenders so I can still run my 1LE wheels with 305/325 SC3R's.
#8 |
![]() ![]() ![]() ![]() ![]() Drives: Chevrolet SS 1LE Join Date: Oct 2019
Guys, he doesn't have the ZL1 1LE. If he did, it would be the faster and better track weapon because it has the extra power but also the extra cooling to keep it happy on track, and it also has a much more track-focused suspension (it's not just the tires). As it is, I think the OP might be happier on track with the lighter, more consistent, and more reliable SS 1LE. If he swapped over the SLP and DSC equipment, it would like be even better just due to the ability to get more camber front and rear and add a more track-focused damper calibration.
Matt Miller
2020 SS 1LE |
#9 |
![]() Drives: 2018 Hyper Blue 2SS 1LE Join Date: Aug 2018
you don't need ZL1 front fenders to run 11" wheels up front. 11s fit fine with the SS fenders. it does poke a little if you don't run much camber. But another downside(maybe) of running the ZL1 fenders is that you will also need the ZL1 front fascia. ZL1 fenders don't match up with the SS front fascia.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:28.95 Willow Springs Big Track |
#10 |
![]() Drives: 2021 1SS 1LE Join Date: Nov 2020
I had a stock motor, but modified chassis SLE and went for the ZLE. A few reasons....
1) More power 2) Better electronics 3) Closer 4th-5th gear (M6) spread 4) Functional aero Sure, I could have spent 20k for a heads/cam/exhaust NA deal and another 5k for the aero, but I still would have the 4-5 gap and not as good electronics. I LOVED my SLE and am bummed I sold it, but for a lap time, ZLE easily wins. My best in SLE vs the worst in ZLE is 2 seconds per lap and I'm sure the spread would be more if I kept driving it at that track. Post #268 - https://www.camaro6.com/forums/showt...594295&page=20 Ken
Follow my build - https://www.camaro6.com/forums/showthread.php?t=594295
#11 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
I've been looking into cam/heads and I think you can DIY something for around $5k including new lifters for reliability, get within 50 hp of an LT4 (+100 whp), and rev to 7k. You save around $5k in labor if you do it yourself and it doesn't seem all that bad...
#12 |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
I know that this is not the exact comparison that you want. I took a ZL1 as close to a ZL1 1LE as I could, then transitioned to a ZL1 1LE. I added full 1LE aero, 1LE wheels with 3R tires, DSC Sport Controller, etc to the ZL1. Lap times were within .5 seconds of the ZL1 1LE. The main difference is how the cars drove at the limit. Due to the softer suspension, the ZL1 had more corner exit grip, but had excessive understeer. The car was less predictable at the limit, sometimes it would snap instead of a smooth correction. The ZL1 1LE is extremely neutral and predictable. You can find the limits smoothly and bring the car back if you cross the limit. The predictability builds driver confidence and will drive consistently faster laps times than the modded ZL1.
Parts of this comparison are relevant to a higher horsepower SS with aero compared to the ZL1 1LE.
#13 | |
The main reason I am wanting to do this is because the car can't be tracked in the hotter months (I live in Texas, it is always hot) due to the supercharger coolant getting too hot. I have been chasing cooler temperatures for months now with moderate success. I have done a chiller, expansion tank, fender tank, aftermarket oil cooler, FlexFuel sensor, and GMS front impact bar, all in the name of cooler MAT's on track. I have a few options right now and not sure what I want to do: 1. Swap the OEM blower for a 2650 to keep it cooler. ($8k+) 2. Pull a ton of power out of the car and run higher E%. I don't know if this is even possible. I have very basic bolt ons. 3. Only track it in the cooler months 4. Sell the car and buy an SS 1LE. Transfer most of my parts from the ZL1 over. At the end of the day, an SS 1LE and a regular ZL1 are very similar cars beside the power difference. If the SS makes close to ZL1 power with less weight and N/A, it would Basically be a 6th Gen Z28. It just seems like a simpler car and less things to worry about. If I keep my ZL1, or if I owned a ZL1 1LE (SS 1LE as well), I would eventually put MCS coilovers on it anyway. That would take the ZL1 1LE out of the equation IMO (fully putting my standard ZL1 on 1LE level). I am really happy with all of the responses from the group. I appreciate all of the feedback and experiences from everyone.
2022 M6 Rapid Blue ZL1 (SOLD) Last edited by Rapid_blue_zl1_22; 09-25-2024 at 01:56 PM. |
#14 | |
![]() Drives: 2019 ZL1 "1LE" | 16 SS | 2017 F30 Join Date: Dec 2021
Manifold air temps are on average at around 140°F when I tracked in April. With the impact bar removed it will run even cooler. The callaway uses also a bigger intercooler, it literally starts right above the transmission cooler. A chiller and a fender tank wont help imo. It just increases the area of picking up more heat from the engine bay. It will only delay heat soak for a short amount of time. I only had to install an oil cooler.
Callaway SC750 ZL1, DIY 1LE with added OEM 1LE Wheels, DSSV Suspension and 1LE Aero, FEA front control arms, DIY oil cooler, CWA 150 pump, bigger intercooler, BMR lockout kit, CTSV Brake Air Deflectors, Smooth idle cam, LS7 lifters, CHE trunnion bushings. Tuned by JRE
