Old 09-04-2024, 03:36 PM   #1
White1SS
White1SS's Avatar
Drives: White 2024 1SS M6
Factory M6 clutch max HP
Generally speaking, what level of Hp can a factory M6 clutch safely handle? Purely street driven, no strip or track use. Assume the occasional street dig and roll battle.
White1SS is offline   Reply With Quote
Old 09-05-2024, 07:42 AM   #2
18.2SS.1LE
18.2SS.1LE's Avatar
Drives: Chevrolet Camaro
It's the torque that'll slip the clutch before horsepower, mine is still stock and hasn't slipped once.
Procharger P1X, CSP Big Boy Cam, CSP Headers, LT5 Throttle Body, MSD Intake, LT4 HPFP, LT4 Injectors, JMS BAP, 93 + Boostane - 750+WHP
18.2SS.1LE is offline   Reply With Quote
Old 09-05-2024, 08:06 AM   #3
White1SS
White1SS's Avatar
If you're at 750+ whp, I should be more than fine if I go with a 650 whp build. Are you still on the stock bottom end ?
Old 09-05-2024, 08:40 AM   #4
18.2SS.1LE
18.2SS.1LE's Avatar
Yep, you'll be fine and still SBE over here.
