Go Back   CAMARO6 > Members Area > Ask the Camaro Team
Old 09-04-2024, 06:33 AM   #1
YOHANESJ1
YOHANESJ1's Avatar
Drives: 2016 camaro SS / 2010 Camaro SS - s
reduced power mode!
2016 ss. My car just went into reduced power mode on the highway. I have a solar performance 95mm throttle body installed and a K&N Black Hawk intake installed. I'm Thinking it just needs to be tuned. but I took them both off to see if they are the issue. I will head to the dealer if it happens again. Any input?
Sct4 Tuner
Cat deletes
Vararam Intake
Vararam Throttle body spacer
VMAX Ported Throttle body ring
Pypebomb Catback
IceBlue Halo's
YOHANESJ1 is offline   Reply With Quote
Old 09-04-2024, 01:08 PM   #2
Start The Machine
Start The Machine's Avatar
Drives: 2016 M6 2.0T
Did it happen when you floored it on the highway? Did it say in the dash screen what caused it? My clutch will slip sometimes when I floor it and it goes into limp mode. It says in the dash "clutch slipping" "reduce power" and goes into limp mode for 10 seconds.
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, RPI Designs SS 1LE Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
Start The Machine is offline   Reply With Quote
Old 09-04-2024, 01:41 PM   #3
CamaroSue
CamaroSue's Avatar
Drives: 2019 Corvette GS, 2023 ZL1
My 2010 did that. It was diagnosed as clogged fuel injectors. Scary as hell on the highway!!!
CamaroSue is offline   Reply With Quote
Old 09-04-2024, 11:49 PM   #4
YOHANESJ1
YOHANESJ1's Avatar
it happened on the highway. I was playing with the accelerator reving the motor. I was about to launch and it shut down. It also happened on a side street when I was leaving home and I limped back to my house about a block away. We ran the code, throttle position sensor.
Sct4 Tuner
Cat deletes
Vararam Intake
Pypebomb Catback
IceBlue Halo's
Old 09-05-2024, 12:49 PM   #5
Start The Machine
Do you have the Solar Throttle Controller installed?
Old 09-05-2024, 11:59 PM   #6
YOHANESJ1
YOHANESJ1's Avatar
no.
Sct4 Tuner
Cat deletes
Vararam Intake
Pypebomb Catback
IceBlue Halo's
Old 10-04-2024, 02:26 PM   #7
ctrlz
There is a service bulletin for this. Mainly a problem in 2016's. Reluctor wheel not torqued adequately:
https://www.camaro6.com/forums/showp...7&postcount=10
