Old 09-03-2024, 12:08 PM   #1
beworthy3
beworthy3's Avatar
Drives: 2018 Camaro SS 1LE
Anybody know how to recline the seat when its out of the car
I recently put an OMP seat in my car, the OEM seat has just been in my house. But now I want to build a sim and want to use the OEM seat, but I had to angle the seat pretty far forward to get it out of the car. Does anybody know how i can recline the seat with it not connected to the car?
beworthy3 is offline   Reply With Quote
Old 09-03-2024, 12:45 PM   #2
willzilla
D3RPZILLA
willzilla's Avatar
Drives: 2021 Camaro ZL1 a10
Maybe carry it over to the car and set it next to the car and try to stretch the seat harness plug over to it and plug it in?
Website: z1lla.com | YouTube: sub.z1lla.com | Merch: Shop & Etsy
YouTube Playlists: Performance Mods | Show Mods | Other Mods
willzilla is offline   Reply With Quote
Old 09-03-2024, 12:50 PM   #3
beworthy3
beworthy3's Avatar
The last thing I want to do is take that bucket seat out of the car lol, everything about that install was a pain in the ass
Old 09-03-2024, 02:01 PM   #4
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
If you knew what the positive and negative are on the harness, you can just jump it with a power tool battery pack to power it up.
Old 09-03-2024, 02:11 PM   #5
willzilla
D3RPZILLA
willzilla's Avatar
Maybe something like this, https://amzn.to/47cmkxv, and inject power into the seat harness and then use the recline switch to move it back into proper position. I'm not sure if there is a pin out diagram somewhere for the plug for which is positive and negative pins.
Old 09-03-2024, 02:51 PM   #6
CalgaryZL1
CalgaryZL1's Avatar
That is another great option, I use mine quite often for temporary power. But I think he’s looking for something he can use in the house.
Old 09-03-2024, 03:47 PM   #7
beworthy3
beworthy3's Avatar
This might actually be what I need, I only need to move it once to set an angle I want, after that I wont adjust it again. Thanks!
Old 09-03-2024, 04:41 PM   #8
willzilla
D3RPZILLA
willzilla's Avatar
No problem, good luck! I'm sure there is a pin out of the plug somewhere
Old 09-04-2024, 08:31 PM   #9
koolkat68
Drives: 2022 Vivid Orange Metallic LT1
Maybe this will help.
koolkat68 is offline   Reply With Quote
Old 09-05-2024, 08:12 AM   #10
Number 3
Hail to the King baby!
Number 3's Avatar
Won't necessarily be cheap, but the easiest way is to get a body side connector to the seat which per the wiring diagram from koolkat68, you should just be able to apply 12 volts from a battery.
Not the easiest way, but it will certainly work. That and as mentioned by others, this will give you an easy way to adjust the seat over time or for other drivers in your game. You know if you ever allowed guests to play
Hard is that connector is likely part of a much bigger wiring harness so $$$. Maybe junk yard or on line???
Old 09-05-2024, 09:43 AM   #11
FactoryMatt
FactoryMatt's Avatar
Drives: '22 2SS 1LE
not sure, but sim racers do it all the time. maybe check reddit.
FactoryMatt is offline   Reply With Quote
