![]() Drives: 2019 camaro ss Join Date: Nov 2020
Low side for Port injection
I'm currently running out of fuel with my lt4 in tank and auxiliary pump. I want to add port injection and my engine builder suggested removing the aux and installing the fore triple pump. I really don't want to do that and was wondering if my current set up would work with the added port injection. My ultimate goal is 4 digits at the wheel. Any help would be greatly appreciated.
Forgot to add my current setup is Maggie 2650 and flex. Furl. My bottom end is lt1 so I plan to forge internals and use a cam that will push the lt4 pump better.
#3 | |
Moderator
#4 | |
![]() Drives: 19’ ZL1 A10 / 16’ C7Z M7 Join Date: Apr 2021
It's not that I have anything specific about the Fore set up I don't like, just was wondering if the lt4 in tank and aux pump was enough to support the port why tear it out? If it won't work then the Fore is the best option?
It really depends on how much power you want to make. You can make well over 900 with as Mike did with his stock Lt4 in his C7 Z06. His port injection is the ticket with the Maggie 2650, he made 963 on 22 psi of boost and 26 degrees of timing. You can make a nice street or drag strip car surpass 850 on less boost and timing. However, you will have to add the low side for sure.
#7 |
What specifically are you referring to when you say add the low side? Remove the auxiliary pump setup and go with the Fore trjple?
#8 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
You could also drop in a DSX or Katech dual pump in the tank. Both are a nice drop in solution that remain returnless.
Mods being installed- oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc. |
#9 |
If you want 4 digits at the wheels, you're going to need the Fore.
The aux pump just can't handle the demand, nor will LT4 injectors (even with the big lobe cam). I wish I had done the Fore pump upgrade, THPSI plates and forged pistons when I first installed the 2650.
James Montigny
2017 Camaro 2SS A8 - Krypton Green Magnuson 2650 @ 13psi, Forged TSP Rods/Pistons, TSP Ported Heads, BTR PD Cam, Aeromotive Low Side, DSX Flex, LT4 HPFP, 103mm TB, Big Gulp, Meth. Built by Killer Performance, Tuned by Justune. |
#10 |
James, that's the answer I was looking for. My builder suggested the Fore, I just wanted to make sure I was going to need it. I'm definitely wanting to break 4 digits at the wheel so I guess the triple pump is a Fore gone conclusion! Sorry, I couldn't resist...
#11 |
![]() Drives: 2018 Camaro ZL1 A10 Join Date: Feb 2022
You can do it with E50, not with E85.
#12 |
Petro-sexual
If you don't care about CARB where you are, FORE.
I'm not sure a stock calibration will run the primary pump in the FORE, nor if you care/need to worry about fuel sloshing around in the tank (e.g. auto_X or road racing-type stuff), but if you don't - FORE. DSX shows they're good to 1200 I guess, too. That might cover the concerns I was talking about.
#13 | |
#14 |
Carb not a concern however i would like to be able to auto cross/track the car and have heard of guys having issues with the Fore setup. Uograding the auxillary pump would be a much easier route if that would work. Do you know anyone who has gone that route? Would there be anything gained from using a different in tank pump in conjunction with the larger aux? Im currently running an lt4 in tank pump.
