Old 08-30-2024, 04:39 PM   #1
Hostile_1LE
Hostile_1LE's Avatar
Drives: 2020 Camaro SS 1LE | Satin Steel
Highest compression on 93?
I am thinking of bumping my compression up in December when I have my motor out. Currently I am running too little compression (11.5:1) for my cam. I still want to be able to run pump 93 octane without having to us octane booster, but I want to give my cam some more comp to play with.
What is the max compression I can run and still be able to put 93 in the car and have it be happy.
Currently I am HCI with:
SS3
GPI Ported Heads
MSD
103mm
Roto-Fab
1 7/8" catless LT's
E85
Full 3" straight pipe
GPI Tuned
Car weighs nearly 3900 lbs with me in it.
My guess is 530whp based on the runs with others cars that I've gotten.
HCI | GPI SS3 | E85 | xxx whp \ xxx tq
Hostile_1LE is offline   Reply With Quote
Old 08-30-2024, 04:41 PM   #2
Hostile_1LE
Old 08-31-2024, 02:04 PM   #3
m6-lt1
m6-lt1's Avatar
Drives: 2012 Shelby GT500
No expert but the Mustang GT runs 12:1 and works on 93 fine. Not sure if this has anything to do with it but Mustangs run DI and Port injection. It’s my understanding that Chevy switching to DI on the LT1 is what let them bump compression from 11:1 on the LSX engines to 11.5:1. Based on that I wouldn’t think the Mustang having port injection as well is what lets Ford run 12:1. Again not an expert but I think Ford runs larger gaps on the coyote piston rings. No idea if that’s why they get away with .5 more compression or not.
It is my guess that anything above 12:1 is too high for 93. I have read on these forums that people see knock on their logs with 93 however I can’t remember if that’s the LT4 or the LT1 or both.
I think you’re going about it the smart way by trying to stick to 93. Some people go to high for 93 and run e85 only but then you gotta test the quality e85 you’re getting and you can no longer road trip the car as a good chunk of the country doesn’t have e85.
To confuse you even further, the current Miata runs 13:1. No idea what so ever why they can run that high.
2012 Shelby GT500 with VMP Gen 3R.
Prior:
2023 Camaro 2SS 1LE
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
m6-lt1 is offline   Reply With Quote
Old 08-31-2024, 05:20 PM   #4
s346k
s346k's Avatar
Drives: like an old lady
i would speak directly with whoever is tuning your car. because ultimately how well the car runs on a handicap like that will point directly at them.
Old 08-31-2024, 06:18 PM   #5
NYblack1le
Drives: 2018 1SS 1LE
Coyote is a DOHC. Completely different ball game. The static compression means nothing. 4 camshafts and vvt make things like this possible along side DI.
NYblack1le is offline   Reply With Quote
Old 08-31-2024, 06:22 PM   #6
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Bingo. Dynamic compression > static compression
Joshinator99 is online now   Reply With Quote
Old 08-31-2024, 10:27 PM   #7
m6-lt1
m6-lt1's Avatar
Gotcha. Didn’t think that mattered but now that I think about it makes sense. Same thing with miata I guess since they run 13:1 which I still find amazing.
Prior:
2023 Camaro 2SS 1LE
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
Old 08-31-2024, 10:45 PM   #8
Joshinator99
Moderator
Yes they can use the independent cam timing to bleed off cylinder pressure…
Old 09-01-2024, 07:50 AM   #9
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
As its already said, its all about dynamic compression. The Engine Builder, if they spec'd the cam, should have the info you seek.
That said, 12:1 static typically isn't an issue with 93 pump but the camshaft design will be a factor in how much timing you can put in it.
GM Gen V Calibrator
Old 09-02-2024, 07:19 AM   #10
laynlo15
Drives: 2022 Lt1 A10
Leave it at 11.5.
Old 09-02-2024, 11:36 AM   #11
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
Originally Posted by Hostile_1LE View Post
That was a good run between the Mustang and camaro.
Old 09-02-2024, 11:43 AM   #12
Hostile_1LE
Leave it at 11.5.
Why? I’ve got a cam in it that needs a higher dcr, and the only way to get that is a higher SCR. Plenty of guys out there running 13:1.
Old 09-02-2024, 11:50 AM   #13
FlukeSS
FlukeSS's Avatar
The other issue is if you plan to Turbo/SC it later.
If you run the higher compression I believe that eliminates possibility of using a Turbo/SC?
The lower compression allows you that lee-way if I am not mistaken?
Old 09-02-2024, 12:33 PM   #14
Hostile_1LE
yes, high compression is less boost friendly but I don't plan on boosting it. besides, it would need a shortblock rated for at least 1000 for me to consider boost, which I could easily get in a lower compression.
