Old 08-29-2024, 04:33 PM   #1
FarmerFran
FarmerFran's Avatar
Floor Jack
Need to semi low profile quick floor jack but that can go to truck (1500) heights,
Any recommendations?
<Insert Cars You Own Here>
Old 08-29-2024, 05:20 PM   #2
cthulhucaller
Drives: 2022 1SS Team Joe and Becky
Low profile floor jack and a chunk of 4x4 has met all my low car and full size truck needs.
cthulhucaller is offline   Reply With Quote
Old 08-29-2024, 05:37 PM   #3
FarmerFran
FarmerFran's Avatar
I guess I should have specified... any specific brand to get or stay away from?
Old 08-29-2024, 07:24 PM   #4
Ryanbabz71
Ryanbabz71's Avatar
Use this harbor freight jack on my car and Silverado
Sent from my iPhone using Tapatalk Pro
Ryan
Old 08-30-2024, 06:12 AM   #5
Warrior102
USCG Retired (MKC)
Warrior102's Avatar
Drives: 2018 2SS 1LE Black
The one thing Harbor Freight sells thats GTG, Daytona low profile high lift jack.
https://www.harborfreight.com/automo...een-64785.html
Warrior102 is offline   Reply With Quote
Old 08-30-2024, 07:47 AM   #6
Seconding that. I have this exact floor jack in blue, it works perfectly with my Camaro that I installed lift point blocks on as well as our other vehicles, and has a pretty good height range from about 3" to over 24".
Old 08-30-2024, 09:01 AM   #7
cbironman
Drives: 1967 Camaro SS, 2022 Camaro LT1
I have this same one, works great on the Camaro and my AT4 1500
cbironman is offline   Reply With Quote
Old 08-30-2024, 09:02 AM   #8
FarmerFran
FarmerFran's Avatar
That is the one I was looking at and it is $40 off, nice
Old 08-30-2024, 10:12 AM   #9
Warrior102
USCG Retired (MKC)
Warrior102's Avatar
Don't forget jack stands, these fit the clamp on lift blocks like a glove, won't pinch your fingers and are made of aluminum. https://www.amazon.com/Torin-Big-Alu...993057786&th=1
Old 08-30-2024, 10:58 AM   #10
cthulhucaller
Sorry. I have a Daytona low profile, and an older Pittsburgh. Both have served me well, but the Daytona is a little nicer and smoother.
Old 08-30-2024, 02:01 PM   #11
Gen6cyl
Drives: Chevy Camaro 2021 ,rs, v6, manual
Gen6cyl is offline   Reply With Quote
Old 08-30-2024, 02:08 PM   #12
Standard
Drives: 2023 ZL1 M6, 2010 SS M6
My 2c, though it's deviating a bit from your question.
When you boil it down, you're asking here to jack up your Camaro6. . . . I can only speak to that wrt the big Daytonas.
Others may have different experiences; but mine:
1. The lift-pads are probably great for when you have lifts; but I find them troublesome/impossible around skirts as they don't get you past the skirt to lift, and IMHO maybe a tad dangerous over jack stands.
2. For the job of lifting your car up in a reasonable amount of time, having TWO good jacks to go back and forth incrementally adjusting your jackstands far exceeds having just one.
3. To get onto the side of your Camaro, and get around skirts sufficiently, these are great https://zl1addons.com/collections/ja...-3-jack-magpad . Get one for each jack/side. Notice how far it gets you away from the contact point before getting to the circle (and where your jack touches).
Standard is offline   Reply With Quote
Old 08-30-2024, 02:59 PM   #13
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
i have harbor freight one had it almost 10 years no issues
Old 08-30-2024, 08:03 PM   #14
fj5gtx
fj5gtx's Avatar
Drives: 70 GTX, 06 Mustang, 22 Camaro LT1
I recommended this to my friend for his suburban (or whatever they call those now)... I call it the school bus.
I've borrowed that daytona, works nice, lifts really high ... but its HEAVY to carry around ! If you're just going to roll it around, weight won't matter much.
https://www.harborfreight.com/3-ton-...lue-56641.html
2022 CAMARO LT1 COUPE AT10
fj5gtx is offline   Reply With Quote
