Old 08-29-2024, 10:50 AM   #1
Harry76
Harry76's Avatar
Drives: 2018 ZL1 A10 Nightfall Gray
A10 Transmission Upgreade
My Transmission is failing after 45k, the new motor is too much for it.
What are you higher horsepower guys doing to make the 10L90 live over 1200 hp?
Harry76 is offline   Reply With Quote
Old 08-29-2024, 11:23 AM   #2
Z OH 6
Drives: 2024 CT5-V Blackwing
ZL1 Atlanta will be along soon to answer this.
Old 08-29-2024, 01:28 PM   #3
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
TH400 swap or rebuild the A10 frequently depending on usage.
Old 08-29-2024, 01:50 PM   #4
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Is Midnight Performance only Ford for the 10-speeds? LMP mentioned they started rebuilding, in-house, and will only build if they tune it or something. Tim King is someone else I have heard of.
I've not had any experience with any of these guys (but have heard good things about them), and, also, don't know if they build the tranny to 1200 behind the butth0l3 or wheel.
'20 ZL1 Black "Fury"
Old 08-29-2024, 02:06 PM   #5
Harry76
Harry76's Avatar
Thanks Guys, after some research I am going with Tim King, from Ohio.
https://www.facebook.com/TimKingRacing/
Old 08-29-2024, 03:31 PM   #6
jlaudio11
jlaudio11's Avatar
Drives: Chevy Camaro
Depending on where you are in Indiana and if you're wanting to stay local. Ethan Patterson of WP Developments has been building 10r80's for a little while. The major components are identical inside.
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, et street r’s on racestar recluse wheels.
1.33 3.75 5.75@122.98 1/8 pb 9.04@141 1/4 pb technically
'94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, otr intake
jlaudio11 is offline   Reply With Quote
Old 08-29-2024, 03:39 PM   #7
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
I do whatever ZL1Atlanta did (which I think involved Tim King)
Mods being installed-
Old 08-29-2024, 03:54 PM   #8
jlaudio11
jlaudio11's Avatar
No he runs a pure drivetrain solutions build
Pure, midnight, along with Fisher built all have high hp setups out there. How long there living, I can't really comment on.
'20 Camaro LT1
Old 08-29-2024, 04:02 PM   #9
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
My bad. Thanks for the correction! Whatever he's doing it seems to be working (for some period of time, anyway)
Old 08-30-2024, 05:22 PM   #10
Xelor
Drives: 2022 ZL1
They have a racing transmission shop offering full race A10 for 8k each.
Xelor is offline   Reply With Quote
Old 08-30-2024, 06:10 PM   #11
JSH
JSH's Avatar
Drives: '20 ZLE
I thought his was a T400
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 08-30-2024, 06:41 PM   #12
Z OH 6
No, he has the quickest boost only ZL1 in the country still using the 10L90. If he had swapped to a TH400, he would likely already be in the 7's.
Old 08-31-2024, 08:58 AM   #13
KingLT1
KingLT1's Avatar
Yes and he has had to rebuild the A10 several times to get there. He has even said it multiple times that it's not a easy feat to go that fast with the A10. They don't like power levels above 1100+ whp. I don't know if it's tuning support, mechanical limits, or both. Hopefully he will see this thread and chime in. I know many have went right to the TH400 vs rebuilding a A10 every few track outings.
Old 08-31-2024, 09:05 AM   #14
Z OH 6
Yea, he has a goal to run 7s with the 10L90 so it's been tough. For his purpose and he would certainly agree that a TH400 is the better way to go and I think if he ever hits 7s with the 10L90, he will likely go that route. I can appreciate what he's doing though because it helps develop parts for the 10L90 to take it as farther than most people will ever want to go.
