![]() Drives: 2016 SS Nightfall Gray Join Date: Oct 2016
6 Vehicle Issues
I have a 2016 SS bought new from a dealer. It has been flawless.
Today, I opened my "mychevrolet.com" app and it showed "NEEDS ATTENTION" for the following: - Engine and Transmission System - Antilock Braking System - StabiliTrak Stability Control System - Air Bag System - Emissions System This floored me so I went online to Onstar and it showed my vehicle status as "All good to go", and the car drives like new. I saw other posts listing the same issues, so I wanted to chat with a human. I got an advisor and ran this issue by them and got an immediate response: the Onstar system needs troubleshooting, and perform the following: To perform a troubleshooting on your vehicle, please follow the steps below: 1. Please turn your vehicle's ignition on for at least 2 minutes 2. Turn ignition off and wait 2-5 minutes (so data can be collected). 3. Once done, close the app and log back in I did it, opened the app and everything is fine. Nothing to do with the AFM disabler or anything else...FYI |
![]() Drives: 2020 Camaro SS 1LE | Satin Steel Join Date: Jan 2022
I think a more reliable source of info on your car's health would be the OBDII port.
HCI | GPI SS3 | E85 | xxx whp \ xxx tq
![]() Drives: 2022 1SS Team Joe and Becky Join Date: Apr 2021
This goes for any issue reflected in the app that does not have a corresponding fault light or message in the car. It's not a car issue, it's a incomplete data to the app issue, and can happen once in a great while. The troubleshooting step offered by the OP fixed me up in the past too.
![]() Drives: 2023 ZL1 M6, 2010 SS M6 Join Date: Oct 2009
I saw someone post this to a facebook group, and while I was using the app successfully a day ago, I saw today that I got it too.
I'm guessing it's a more universal problem with their comms, server or app. |
As others stated, mrtoner, you most likely have nothing to worry about if the check engine light or other warning lights on the dash aren't on, and any cheap OBD-II port scanner could confirm this.
This notification glitch is not uncommon, I had this happen several times until I unsubscribed from OnStar and GM "helpfully" turned off my app access after 5 years of owning the car.
Hey guys. Thanks for all the input.
I considered it odd since I had no CEL or other warning lights. I also had plugged in my OBD II scanner and came up blank, so I knew something was up. Since so many others were reporting it, I still wanted to find the cause, and sure enough, it was a sync error in the OnStar communication. |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
How is the battery? Newer cars can do some goofy stuff if the battery is low or dying.
<Insert Cars You Own Here>
#8 |
My app is showing the same issues. I knew there were no issues. Thanks for posting the fix.
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4 | Range AFM Disabler
Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo | Footwell Lighting | Umbra Sequential LED Taillights ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Banks Data Pro and Pro gauges in ZZPerformance pillar pod | Paddle shifter extensions |
#9 |
The car wasn't the one doing goofy stuff this time, it was OnStar.
#10 |
#11 |
I get that, I say it because when OS pinged the car it might have sent hermagerbles back.
#12 |
376 cubic inches of fun
Lately, on all 3 of my GM cars, I have found that OnStar is not up to date on problems I can see in the vehicle, until many days later.
As for all these errors showing up at once, I agree that a weak battery is the first place to look. All these built in test sensors aka "BIT" are over-sensitive to voltage drops. If your battery is more than a few years old, or if your car often sits for extended periods without a battery tender, or if you are new to a used car, getting a new battery is the thing to do. |
#13 |
Battery.
#14 |
ZL1 Driver
Drives: Camaro ZL1 & BMW M3/E92 Join Date: May 2009
Had the same issues with both Chevrolet's we own. It's onstar at fault. I'm seriously considering dropping service, especially after the incident of GM selling our data to others without our knowledge.
