Old 08-16-2024, 11:37 PM   #1
db2022cs
Drives: 2023 2SS 1LE
Heat issues with headers
So, I got headers installed about a month ago now with a tune and E85. When the headers were installed they also installed MSD wires for the spark plugs. After a couple weeks I took it to the Tail of the Dragon and did some runs so I definitely put some heat into them. While I was there, I never smelled anything out of the ordinary. A weekend later I was driving normally and I started smelling a burning plastic smell. It looks like the portion of the steering shaft that has a plastic cover has started to melt. I had brought a question up to the installer who works on a lot of Camaro's and Corvettes about any precautions to take for the increase in heat from headers. They said they haven't had any issues other than spark plug wires which I had getting replaced with upgraded ones. I asked on the Facebook group and after filtering through 80% of the BS responses some have said it's a cover and cut off the burning plastic piece and others have suggested using some sort of heat wrap. Any suggestions on what to do with the extra heat? Am I going to have to bite the bullet and have the headers pulled off and wrapped or can I just cover up spots I can reach with some exhaust wrap or DEI gold tape? Thanks in advance.
2023 Riverside Blue Metallic 2SS 1LE Camaro
2021 Black Hyundai Veloster N -Sold-
2016 Grey Chevy Volt -Sold-
2018 Blue AWD Kia Stinger GT2 -Sold-
db2022cs is offline   Reply With Quote
Old 08-17-2024, 08:37 AM   #2
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
What brand headers? Speed Engineering?
GM Gen V Calibrator
Old 08-17-2024, 08:59 AM   #3
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Hate to sound like a broken record, but I’d never install headers on this car without ceramic coating or wrapping…
Old 08-17-2024, 09:52 AM   #4
6spdhyperblue
Drives: 2SS 1LE
I had tsp 2” wrapped with msd wires at pocono. They worked without issue
Old 08-17-2024, 12:24 PM   #5
db2022cs
Yeah, I took the word of the installer saying there wouldn't be any issues. Guess that is on me. Looks like I'll have to take it easy until I can get it back to a shop to have them pulled off and wrapped and done the right way. If that is going to be done, is the heat shield on the starter fine or should I look at a a DEI heat shield since the headers will probably be off anyways? Thanks for the responses. Love the headers and E85 besides this annoying issue.
Old 08-17-2024, 01:17 PM   #6
6spdhyperblue
Drives: 2SS 1LE
Get them coated
Old 08-17-2024, 01:45 PM   #7
AZIROC
Drives: '86 IROC-Z '18 ZL1
I'm guessing the headers aren't coated?? I'm a firm believe since the late 90s that coated headers are well worth the extra few $100. I've just never been a fan of wrapped headers either. Imo, if the headers have to come off, see if you have a place local that can coat them.
Old 08-17-2024, 03:17 PM   #8
Originally Posted by 6spdhyperblue View Post
Get them coated
x4
My headers are coated and never had any temp issues, they're reasonably but not excessively hot, and the engine bay area around them (wires and everything) looks pristine.
Old 08-17-2024, 07:02 PM   #9
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
You don't need to coat quality stainless(high end stainless) headers that fit properly such as kooks and ARH.
The rest.......yeah you get what you get.
While is does make everyone feel good when they coat their headers, it's unnecessary for 99% of the cars on the street. There is a place for it but a bolt on or cammed Camaro SS or ZL1 isn't one of them. It does not help performance either at the street car level. Pair them with a set of MSD plug wires that you can shape to the angle that you need, and you never have to worry about burnt plug wires either.
GM Gen V Calibrator
Old 08-17-2024, 08:45 PM   #10
RideWithDanger
RideWithDanger's Avatar
Drives: 23 2SS 1LE
Even with Kooks headers you should get them coated. It keeps everything cooler in the engine bay, which helps performance as well. Not to mention it helps avoid issues like this as well. You can get DEI boots over the wires but coating the headers is the best option.
Instagram: RideWithDanger
Current Mods: Rotofab, Ported LT2 intake, LT5 TB, Kooks Headers, AWE Touring Catback
Radiant Red 23' 2SS 1LE
1100: 11/14/22 | BUILT: 3/16/23
2000: 2/17/23 | 4200: 5/8/23
3000: 2/27/23 | 5000/6000: 5/15/23
RideWithDanger is offline   Reply With Quote
Old 08-17-2024, 09:46 PM   #11
Joshinator99
Moderator
Agreed. That passenger side wiring harness is a disaster if that gets melted so ceramic coating is a no brainer.
Old 08-18-2024, 05:04 AM   #12
s346k
s346k's Avatar
Drives: like an old lady
i put 25k miles over a course of 3 years on my (uncoated/unwrapped) speed engineering 2" headers. the plastic collar on the steering shaft melted and deformed a bit. the car made countless high speed pulls, sat in 100* weather creeping in traffic for several hours year after year on the hot rod power tour. 0 issues.
however i am not a fan of msd plug wires. i initially installed a set that ended up burnt from heat, no contact. i replaced them with granatelli wires, wish i had done that to start with.
Old 08-18-2024, 07:46 AM   #13
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
The wiring harness should be moved regardless of header coating or not. We've done countless uncoated header installs and have never burned the harness.
I would attribute that to the Speed Engineering header collector angle along with improper boot shaping when install on the spark plug side. We never have issues with MSD wires with uncoated ARH and Kooks headers.
GM Gen V Calibrator
Old 08-18-2024, 08:49 AM   #14
6spdhyperblue
Drives: 2SS 1LE
My biggest concern is wear and tear from the heat on the starter circuit
