Old 08-15-2024, 09:13 PM   #1
beworthy3
beworthy3's Avatar
Drives: 2018 Camaro SS 1LE
Which titanium lug nuts do you use?
What titanium lugs do you use?
I think i unseated one of my wheel studs trying to fight the impact off the lug nut, the lugs have just been deformed due to heat. So i think it’s time to get titanium ones as i heard they don’t deform
beworthy3 is offline   Reply With Quote
Old 08-15-2024, 09:44 PM   #2
Anom1LE
Anom1LE's Avatar
Drives: 18' 2SS 1LE, 94' Z28
I am running Raceseng burnt titanium. Worth the coin for sure
2018 Camaro 2SS 1LE - 1,xxxHP
D-1XH Procharged, LME 416, GPI/CID Track Attack Heads, BTR top end,
Katech oil pump, Pray Tuned, Stainless Works, Anderson Composites,
13GFab, BC Forged & More
1994 Camaro Z28 - 7xxHP
Nitrous Outlet Direct Port Nitrous & more, Creator of AggreSSive spoiler,
Multi Magazine Featured Camaro Z28 in GMHTP, Super Chevy,
Nitto, and Camaro Performers
Anom1LE is offline   Reply With Quote
Old 08-15-2024, 09:51 PM   #3
SDF62
Katech 12 Point
SDF62 is offline   Reply With Quote
Old 08-15-2024, 11:37 PM   #4
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
I have removed and replaced my wheels at least 30 times per year since new (over four years now) and tracked it to the point of recurring brake fade, all while using steel lug nuts. I have done the same with many previous cars going back almost 40 years. I have never, ever seen a steel lug nut deform due to heat. Your aluminum wheels would melt long before a steel lug did.
Matt Miller
2020 SS 1LE
Msquared is offline   Reply With Quote
Old 08-16-2024, 12:20 AM   #5
beworthy3
beworthy3's Avatar
Katech it is. The raceng ones look dope but that’s a lil more coin than i would like to spend lol
Old 08-16-2024, 06:49 AM   #6
cdb95z28
cdb95z28's Avatar
The impact is doing the damage, not the heat. The shock that impact guns impart to fasteners will stress them. I never break my lugnuts with an impact.
"KEEP THE FAITH"-Fbodfather
Old 08-16-2024, 08:30 AM   #7
m6-lt1
m6-lt1's Avatar
Drives: 2023 Chevrolet Camaro 2SS 1LE
This. You’ll mess the titanium ones as well if you continue using an impact to take them off
Current: 2023 2SS 1LE
Prior:
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
m6-lt1 is offline   Reply With Quote
Old 08-16-2024, 08:42 AM   #8
This x2. I use a breaker bar and a non-marring socket, willing to spend the extra minute to protect the lugnuts. (I do have a 1200 lb-ft ugga-dugga, but never use it on the Camaro.)
Old 08-16-2024, 09:33 AM   #9
NW-99SS
Drives: 1999 Camaro SS M6 - SBE LS1
I will 3rd the breaker bar first statement.
1999 Camaro SS 6M - SBE LS1
1994 Camaro Z28 6M - Golen 383 HT
1963 Corvette GrandSport - ZZ502 4M
2017 Denali 1500 6.2
2017 Yukon Denali 6.2
NW-99SS is offline   Reply With Quote
Old 08-16-2024, 10:33 AM   #10
cmeJATT
cmeJATT's Avatar
Drives: CAMARO
I will 4th the breaker bar first statement
cmeJATT is offline   Reply With Quote
Old 08-16-2024, 11:59 AM   #11
beworthy3
beworthy3's Avatar
Yeah I mispoke, definitely the impact doing the damage, I figured the titanium ones would hold up better. Since not maybe ill reluctantly put the impact down lol.
I remove the wheels so much changing between my autox set and track set that the impact saves so much time
Old 08-16-2024, 01:02 PM   #12
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I think the key is: what impact gun? I use a little Milwaukee M12 impact when swapping between street and Drag racing wheels and it’s been totally fine for the past several years. I run the Harding Performance titanium lug nuts which I believe are the same as the Katech ones.
Old 08-16-2024, 02:09 PM   #13
Msquared
Msquared's Avatar
Now that makes more sense! And I'm with you: there's no way in hell I'm doing all this manually for every autocross and track day I do! I would suggest simply replacing your lug nuts every couple of seasons with good-but-reasonably-priced steel ones. Come to think of it, I need to replace mine soon...
Matt Miller
2020 SS 1LE
Old 08-16-2024, 04:05 PM   #14
apexit53
apexit53's Avatar
Drives: 22 1SS 1LE Summit White
https://katechengines.com/i-30497916...-14x1-5mm.html
I have been using these for a long time now.
#53 F Street
2025 FS National Champion
2025 Sponsor autocrossdigits.com
Autocrossing Videos
https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag
Instagram: apexit_53
apexit53 is offline   Reply With Quote
