![]() Drives: 2020 Camaro SS 1LE | Satin Steel Join Date: Jan 2022
Katech Oil Pump install
I am about to install the Katech oil pump and VVT delete cover... What is the best way to lift the motor? I AM NOT pulling it out of the car. I do have an engine hoist but I don't have a lift plate for the Gen V LT.
Also, I chose to get the truck pump for higher oil pressure. Has anyone done this and can tell me what exactly I need to change in the tune?
HCI | GPI SS3 | E85 | xxx whp \ xxx tq
You need to change the tune because you will throw a CEL when it sees the pressures being higher than they are supposed to be. I was going to get the truck pump as well but swapped back to the regular pump. I couldn't find anything that said the higher pressure was good for your car and only people saying it can cause no issues or more issues.
Kooks ceramic coated headers -1 7/8 in. x 3 in
Pray ported 95MM TB Pray ported MSD IM Rotofab CAI BTR 225 CAM PRC 312 CC Ported Heads Katech Oil Pump DSX Flex Fuel E-85 kit QTP exhaust cutouts Full JLAudio Stereo Build w/ 13-W6 |
I don't THINK you need to change anything in the tune, I think you just have to disable some codes related to higher than normal pressure.
Any info on doing the install with the engine in the car?
#4 | |
![]() ![]() Drives: People crazy with my sexiness Join Date: Jun 2023
Purchase order submitted on 6/23/23
Received and purchased 9/8/2023 2024 2SS 6MT coupe Sharkskin/Light gray Moonroof/Navi/NPP/Mag Ride/Red Brake Calipers Gray painted split spoke wheels Illuminated footwells/illuminated bowtie |
![]() Drives: 1999 Z28, 2011 2SS VERT, 2016 1SS Join Date: Mar 2018
I have a 2016 1ss, I pulled my engine out the top with the hood still on. The oil pan needs to come off the engine and there's a lot of cleaning involved getting gasket sealer off. No oil pan gasket just sealer
Yes, I know that the timing cover, oil pan, and rear cover use rtv instead of a gasket. I recently installed a cam in my car without removing the engine, but I didn't remove the oil pan.
#7 |
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
If memory serves me correct, you need to remove the pan.
You don't need a lift plate, but should chain to at least (4) valley cover bolts IMO. FYI, the lift plates are only like $75. Hope this help.s
#8 |
Yeah I know I need to remove the oil pan to get the oil pump off, as well as to clean and apply new RTV. I am wondering how easy/difficult it would be to remove it without removing the engine.
#9 |
You could hang the engine in the car with a support across the strut towers and drop the k member down possibly. I've done it on 4rth gens but haven't on a 6 gen.
#10 | |
In the sense that its all one man work now, doing "in-car" is easier. Being that you are not doing the heads or cam... I would do in car also.
#11 |
Yeah. I also did the heads cam job mostly solo. I had my brother help me get the radiator out, since I did all of it in the car as well. It was a PITA
#12 |
![]() Drives: 2019 Camaro 1SS1LE Join Date: Jan 2024
I think by the time you monkey around getting clearance for the pan, and doing shit on your back, you will save time and effort just pulling the engine. But if you haven’t already and it’s in the budget, while you are doing the pump get a Katech C5R chain on while you have it opened up.
Otherwise, with a hoist it’s either use a lift plate or a load balancer. I love the load balancer I used for my hoist, took the engine and tranny in 1 shot. Went back in the same way. Was super easy, too. Particularly since I pulled the engine and put it back in solo.
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane 7/26/2024 Tuning in progress |
#13 |
Yeah I ordered the Pump, billet cover with vvt delete and c5r chain.
#14 |
![]() Drives: 2018 Hyper Blue Metallic 2SS 1LE 6M Join Date: Nov 2024
OP, did you complete this task and if so how did it go?
I have a new to me 2018 and am considering preventive oil pump replacement(and associated items). |
