Old 08-12-2024, 07:47 PM   #1
Berto24
Berto24's Avatar
Drives: Camaro SS
Procharged Camaro High IATs
Is anyone else having issues with a procharged camaro SS havimg high iats? Last weekend I went to the dragstrip and was checking my logs and after the burnout IAT were already between 140-150, after the 1/8 mile they reached 200s and stayed there between 200-210 all the way to the end of the 1/4 mile.
Setup is piston and rods 6.2L
LT4 fuel system with Aux Low Side
P1SC1 3.25 pulley
Stage 2 Intercooler
Port Injected Meth and one 20GPH nozzle before TB
A8
Note I am spraying after the MAF, I have the IAT breakout but haven't had the chance to install it.
Berto24 is offline   Reply With Quote
Old 08-12-2024, 08:30 PM   #2
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
P1SC1 3.25 pulley
Stage 2 Intercooler
A8
Your IATs are definitely not that high running meth. I’d install the breakout harness then retest it.
Old 08-13-2024, 08:31 AM   #3
18.2SS.1LE
18.2SS.1LE's Avatar
Drives: Chevrolet Camaro
P1SC1 3.25 pulley
Stage 2 Intercooler
A8
I'm at 12 lbs with a 3.7 pulley, you might be over spinning that P1SC with the 3.25 unless you have a smaller lower pulley.
Procharger P1X, CSP Big Boy Cam, CSP Headers, LT5 Throttle Body, MSD Intake, LT4 HPFP, LT4 Injectors, JMS BAP, 93 + Boostane - 750+WHP
18.2SS.1LE is offline   Reply With Quote
Old 08-13-2024, 11:31 AM   #4
Berto24
Berto24's Avatar
Drives: Camaro SS
Once I get back I am got to try it.
Old 08-13-2024, 11:34 AM   #5
Berto24
Berto24's Avatar
Drives: Camaro SS
I know I am close to the limit based on the procharger calculator so I am guessing its just blowing hot air.
I know at the dyno is not an issue since you let the car cool and just make one pass, altough at the end of the pass IAT were reaching 137.
Old 08-13-2024, 07:37 PM   #6
WiggyB
WiggyB's Avatar
Drives: 2022 Camaro 2SS 1LE
I did this pull the other day when temps were in the upper 90s and I'm running a 3.5 pulley on my setup.
d1sc factory box w/ stage 2 intercooler, Lt4 fueling, JMS BAP, lt2 intake, kooks 1/78 longtube headers w/ h/f cats, alky meth kit, thpsi port injection
WiggyB is online now   Reply With Quote
Old 08-13-2024, 09:16 PM   #7
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
tread stone intercooler(pro chargers isn't great), and tubular crash bar would help a bunch but I would also move up to a D series.
Old 08-14-2024, 03:33 PM   #8
frelira
frelira's Avatar
Drives: 2018 Camaro SS
I would be interested if you have a link to these?
I am running a D1SC with dual nozzle meth and the largest race IC procharger makes for the 6th gen. I did the breakout and iat's went from 200+ to 70-80* under wot so that is great.. but I am going f1a94 next year and port so I think a bigger IC would be better.
I also had to remove the crashbar to install this one.
frelira is offline   Reply With Quote
Old 08-14-2024, 03:54 PM   #9
KingLT1
KingLT1's Avatar
I don't have the link for a IC but I know treadstone makes a lot more efficient IC than procharger. The bars are wider so more air can flow through the fins. Learned more about this with the LS crowd. You will just have to do some digging and see if you can find one that will fit. I think Cordes Performance offers the tubular crash bar?
Old 08-14-2024, 04:43 PM   #10
rcoe
rcoe's Avatar
Drives: 2016 Camaro SS
good crash bar discussion.
https://www.camaro6.com/forums/showthread.php?t=619537
2016 Camaro 2SS 759whp 686wtq tuned by KingLt1
Procharger D1SC - Forged internals
BTR stage 3 cam - Circle Stage 3 trans
American Racing headers - Borla S-type
rcoe is offline   Reply With Quote
Old 08-14-2024, 06:16 PM   #11
Joshinator99
Moderator
Originally Posted by rcoe View Post
That crash bar would not work with a Camaro SS front end…would need to convert to ZL1 bodywork.
I had bought the Cordes crash bar but sold it when I weighed it and it was virtually the same weight as the aluminum stock one (plus no gain in airflow on an SS). The advertised weight savings on the website is incorrect.
Old 11-16-2024, 12:59 AM   #12
Black16
https://www.treadstoneperformance.com/Intercoolers/c8
Black16 is offline   Reply With Quote
