Old 08-11-2024, 09:53 AM   #1
Jetrep
Jetrep's Avatar
Drives: ZL1 1LE, bolt, scary flatbed, hhr,
Question Anti Theft Idea
I might be over thinking this as it seems like a simple solution for a relatively inexpensive cost to prevent our cars from getting stolen
outside of a flatbed / tow truck the path to get the car is the OBD2 port.
Why not simply remove the port and replace it with another design (ex: cannon plug) then make an adapter that could be temporarily installed when the OBD2 port is needed?
I do know there are other ways into the computer through a light wiring harness as an example but the OBD2 port is by far the most common path today
the hacking tools need the OBD2 config and if its not there then the bad guy cant hack it.
it would look like this:
https://www.amazon.com/SZJELEN-5Pin-...=sr_1_7?sr=8-7
Female Cannon plug replaces the OBD2 port in the car
A portable adapter cable with the male cannon plug installs into the female cannon plug and on the other end is the OBD2 port for service needs
outside of a wiring diagram and a day to put this in the idea seems like it would work
oh...and put an "OBD2 Port Removed" sticker on the window and hopefully prevent your window from getting smashed out
ZLE -Fam - what am I missing?
Jetrep is offline   Reply With Quote
Old 08-11-2024, 10:28 AM   #2
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I'm not arguing the idea, because options are great (and I think this is a great one, too), but someone else said something else about "vampire" taps, which could bypass this, or OBD2 locks, too. It take a little more time, and that might be enough to deter them, but I imagine, after stealing enough of these cars, they can get pretty quick at it, unfortunately.
It seems to me, as many already have pointed out - multiple layers are a great idea. Personally - I have 2-hardware layers, and I'll be adding 2-more wiring layers, and probably an OBD2 lock (or something similar to this), too. The way it's working to me is: they see the steering wheel & brake pedal lock (knowing they'll have to spend time cutting and making noise); then see the OBD2 lock, and know they'll be spending time, in the least - cutting/tapping into the harness; then - when they can't communicate, STILL, to the ECM (which will take pulling the car apart), hopefully they'll give up, or I'll be there by that time, and do what I do.
It seems to me any and all deterrents are a great idea, and the more - the merrier. The more you can show they're going to have to work for it (e.g. steering wheel/brake pedal locks), perhaps that will be enough they move on.
JMHO.
'20 ZL1 Black "Fury"
Old 08-11-2024, 01:19 PM   #3
Standard
Drives: 2023 ZL1 M6, 2010 SS M6
In a more general sense, this can be filed under the idea of "security through obscurity", a model for understanding aspects of a security solution that are weak to the point of uselessness. I contrast this with (in the information space) encryption which no matter the knowledge or tools, represent presently mathematically intractable problems.
The "OBD Port program a new key" already has an extreme level of obscurity, around which a $400 tool on amazon exists, as it's a common use case. You could never design this tool from the ground up yourself; but ultimately the knowledge in its software is out there, so it's over.
Even aside from the 'vampire plug' mentioned above, the 'other'->OBD adaptor would just add a 50 cent obscurity barrier.
BTW while not an OBD thing, go find the video on defeating the Ravelco. The guy does some pin-by-pin to find the right ones to fool what your per-user key is doing. OBD remapping would be simpler than this.
Standard is offline   Reply With Quote
Old 08-11-2024, 01:38 PM   #4
IndyZrider
IndyZrider's Avatar
Drives: 21 SHOCK ZL1 M6
that DA showing how to defeat ravelco is just trying to push his igla system...he starts with "i already have the key to the car"....he need power to the car to use his defeat device....so his BS is moot....also you guys should be deactivating your proximity unlock so the signal booster a$$h0!es cant unlock your car with your own fob thats inside your house...jmo....ravelco is a great system....use them in all my vehicles....
IndyZrider is offline   Reply With Quote
Old 08-11-2024, 03:10 PM   #5
Standard
My bringing Ravelco in as an example was a bad idea. It's better than nothing in that 'nothing' is defeated by a tool that exists. . . Ravelco, there is presently not a tool that imitates what the guy was doing in the video.
FWIW, the signal boost/fob doesn't seem to be what the thieves in videos are depending on to boost hellcats (I mention those as in some cities seems there's a 101% theft rate), they swoop in with *certainty* with the key-cloning tool.
Old 08-11-2024, 05:19 PM   #6
Patriot Motorsports USA
Patriot Motorsports USA's Avatar
Drives: 2021 ZLE, C5 Z06 6.0L Procharged
I can buy the Key-Cloning tool right now... and there is nothing short of a sticker on my car telling a would-be thief that I am from Texas and will NOT be calling 911!
A hard wired, non-cellular GPS tracking device that cannot be scrambled is what these cars need and installed in a very remote location.
https://www.amazon.com/dp/B08PPBL1GS...pa_dk_detail_5
Patriot Motorsports USA is offline   Reply With Quote
Old 08-12-2024, 12:59 AM   #7
The Maverick
Somewhere in the Kalahari
The Maverick's Avatar
This general concept has come up before. To further confuse things for a would-be thief, you could install a dummy OBD port (using one of the many OBD port cables sold on Amazon) and then tuck your custom connector up inside the dash so it isn't even visible or easily accessible to a thief. Plus, you can add a lock on the dummy OBD port to give it a look of credibility.
Lots of options!
Old 08-12-2024, 04:14 AM   #8
roostere4
Drives: 1987 IROC, 2020 ZL1
It all comes down to the level of threat you are expecting you need to have and defend against, and for how long you need to prevent a theft. Think of it like ratings on a safe. Give enough expertise, time and certain tools any safe can be broken into. That's why most safes only have ratings in the minutes and not hours.
Any theft prevention measure that is put into a car can be defeated and the car stolen given time. That includes both Ravelco and IGLA, however I would still take IGLA any day of the week over a Ravelco.
however in the end it's still for everyone to decide what threat levels they need to protect against. So the goal generally is to make that longer than what your average thief is willing to invest in trying to steal your car.
roostere4 is offline   Reply With Quote
Old 08-12-2024, 06:39 AM   #9
clg82
Drives: 2020 Camaro ZL1
Can't you just park it in a locked garage and call it a day? Where you guys living where people on the street are stealing your car?
