Drives: Camaro SS Join Date: Aug 2023
Is Y'all Using Mobil1 or AC Delco Synthetic...
What are you peeps putting in your V8s...Mobil1 or AC Delco Synth..Pros and cons of both? ![]() I have used Mobile 1 probably 80 or 90% since new and 70k miles. Last edited by MyNameIs; 08-08-2024 at 03:28 PM. Reason: ;l |
![]() Drives: 2022 2LT RS Convertible Join Date: Apr 2021
I just put the oil in that looks best for my car.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
I put in whatever PostalLDMC recommends
<Insert Cars You Own Here>
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
Neither. 10w40 Valvoline boring dry every day motor oil. For a boring every day SS.
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 Summit White Camaro ZL1 M6 Join Date: Dec 2021
Mobil 1 0w40 for my ZL1. Going to change the oil this weekend.
2023 Dodge Durango SRT (daily driver) 2003 Nissan 350Z (modified) 2022 Rapid Blue 1SS 1LE M6 (delivered 2/19/22) (Sold) 2009 BMW 135i (Sold) |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
M1 Supercar/ESP 0w40 is the correct oil.
#7 |
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
Lucas Synthetic 5W30 in my ZL1 with a Mobil 1 oil filter.
#9 |
![]() Drives: 2023 Camaro ZL1 Join Date: Jan 2016
My ZL1 has low miles and so it is still on some complimentary dealer oil changes that I assume are Delco 0w-40. Which is not an API SP or ILSAC GF-6 spec. But it might offer similar protection.
I will be switching over to Supercar 5w-50 (which is approved in the owner's manual) at the next oil change because it is an API SP oil (0w-40 isn't) and has more zddp (but not enough to damage the catalytic converters). |
#10 | |
![]() ![]() ![]() ![]() ![]() Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
To the op I actually think I read on these boards that mobile one actually makes the ac delco oil.
Current: 2023 2SS 1LE
Prior: 2016 Camaro 1SS 2007 Mustang GT 2008 Civic Si |
#11 |
Amsoil Signature 10W30
...but my engine isn't stock and I live in the South.
#12 |
#13 |
![]() Drives: 2023 Camaro 1SS M6 Join Date: Mar 2023
Only two oil changes in, but both have been Supercar 0W-40 Mobil-1. To my knowledge, this is the only Dexos-R certified oil, and I will continue to use it.
Black 2023 Camaro 1SS Coupe M6
Ordered: April 2022-----Built: July 2022-----Delivered: September 2022 -Dual-Mode Exhaust (NPP) -Red Painted Calipers (J6F) -5 Split Spoke Bright Silver Painted Aluminum Wheels (56W) -Chrome Camaro Logo Fender Badge -Second Generation Front Splitter in Satin Black |
#14 |
![]() Drives: 2016 Camaro Join Date: Oct 2017
Penzoil
Euro L Full Synthetic 5W-30 Dexos 2
2024 Chevrolet 3500HD Z71, LTZ, 4x4, 6.6 ltr. L5P long-bed.
2016 Camaro 2SS Six-speed, Hotchkis sway bars, Eibach .750" drop springs, Mamo throttle body, E85, BMR stuff. 2006 Quicksilver 6-speed GTO ERL LS3-430, All-Pro 285cc heads, 262/273 .758/.742 116+3 cam, Sheet-metal Intake, 70lb Siemens injectors, SLP, GMM Ripshifter, QA1 Coil-overs front and rear, nylon suspension bushings, Hotchkis, RPM Trans, SPEC twin clutch, SpinTech, Kooks 1 7/8 -2.0", BMR drive train, Kaaz 3.91, Lingenfelter CAI, Baer brakes, mini-tubs, E85. |
