Old 08-06-2024, 07:30 PM   #1
Ericdared
Ericdared's Avatar
Drives: 2022 Camaro zl1
Dsx atlas
https://dsxtuning.com/blogs/dsx-tech...controller-faq
So they are expecting it to start at 2k, if you want dual widebands add another 1k. Then plates and injectors are probably another 1k? So you are looking at minimum 3k for port injection not counting the low side. At that price point should we not be looking at just upgrading the direct injection? The only thing I could see for the upside is that with the port injection your upper hp limit would be higher. Am I missing something vital here?
Ericdared is offline   Reply With Quote
Old 08-06-2024, 08:08 PM   #2
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Depends on your HP goal. The Katech/LPE/XDI big DI stuff will let you run 1K WHP already (see my signature). But if you want to go much further than that, especially on full E, then port is pretty necessary.
Old 08-06-2024, 09:53 PM   #3
Ericdared
Ericdared's Avatar
Ok just wanted to make sure I wasn't missing anything. I am all for more options and competition, especially if it causes stuff to get more mainstream and cheaper. Hoping to see some good used xdi and big hpfp for sale here soon.
Old 08-07-2024, 07:02 AM   #4
Joshinator99
Moderator
Well you might be disappointed lol… those of us with big DI stuff would not get rid of that even if we added port injection…. DI makes more power than port so I would run the DI out as much as reasonably possible then use port to make up the difference.
Old 08-07-2024, 11:13 AM   #5
GreyGhost702
Drives: 2019 Camaro 1SS1LE
This thing is disgusting. I kind of want it, lol. I hope I run out of fuel on my build so I have an excuse. Unfortunately due to the lack of E85 in my region, I don't even have an excuse to get away from DI. I'll be using Boostane as a safety blanket. Bumping 91 to 96 octane (approximately).
At least with the PI you're getting the intake valves cleaned as a bonus!
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane
7/26/2024 Tuning in progress
GreyGhost702 is offline   Reply With Quote
Old 08-08-2024, 11:44 AM   #6
MyNameIs
Drives: Camaro SS
Web page tells us nothing of value.
MyNameIs is offline   Reply With Quote
Old 08-09-2024, 07:02 AM   #7
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
It is my understanding this isn't the end-all-be-all. By that, I mean they aren't going to be the only game in town. DSX did admit they can allow for more information after the patent work's done I think. While this looks good and all, it sounds like this integration may not be as complicated as their marketing might suggest. The idea of it sounds fantastic, but I hear, with the technology that's now out there and available, it's not as big a deal as we're being led to believe...
'20 ZL1 Black "Fury"
Old 08-09-2024, 07:03 AM   #8
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
His FB posts say they're looking at about $2K to start.
