Old 07-31-2024, 07:22 PM   #1
rjgss
Drives: 2016 Camaro SS
Pressure test coolant tank
I still can’t figure out where my coolant is leaking from. Thinking it’s the new tank, maybe the cap isn’t sealing right. I don’t know. Took video of pressure test to 20 psi and watch it drop. Lower tank bubbles and not sure why the 2 levels are different now. The connections aren’t leaking. Not sure if I should just buy another tank but would like to know if that’s it.
https://youtube.com/shorts/7t7b1kNVQ...8qXg65EK2Fopyy
rjgss is offline   Reply With Quote
Old 08-18-2024, 04:09 PM   #2
Coded4SS
Drives: 23 Zl1
When dealer pressure tested my car they did it at 10psi. Theres a tube between the tanks and at certain psi it passes through. 20 is probably too high
Coded4SS is offline   Reply With Quote
