![]() ![]() ![]() Drives: People crazy with my sexiness Join Date: Jun 2023
Question for those with serious GM software knowledge
On manual transmissions, it requires you to press both the brake pedal and clutch to start the car. Until I bought this car every manual has only required you to press the clutch - for obvious reasons and I understand them. No problem there.
My problem is requiring the brake pedal as well. So I’ve traced the clutch and brake pedal switch circuits and unfortunately they both go to the BCM, and the BCM actually controls the brake lamp illumination as well. The brake pedal does not have two switches, only one. I’ve thought of every way to bypass the brake switch going through the BCM but still operating the brake lights properly but there isn’t. The only way to fix this is go into the software programming and remove or turn off the BCM looking for the brake input during the starting sequence. Anyone with extensive working knowledge of GM’s LAN system have any ideas? I hate having to press the brake AND clutch - if by chance you stall in traffic with the old way you can punch the clutch and restart without bringing the car to a complete stop. You have momentum which the guy behind you won’t notice if you do it right. But This way someone is almost likely to rear end you!!!! Serious fail!! GM’s engineers had a massive brain fart when they put this “safety net” into the car.
Purchase order submitted on 6/23/23
Received and purchased 9/8/2023 2024 2SS 6MT coupe Sharkskin/Light gray Moonroof/Navi/NPP/Mag Ride/Red Brake Calipers Gray painted split spoke wheels Illuminated footwells/illuminated bowtie |
#2 | |
This "safety" feature was most likely mandated by the same flappers in middle management who forced developers to make us hold down seat memory buttons for the seats to move, or to disable the remote window up feature.
#3 | |
Those flappers obviously never owned a manual transmission as an everyday driving car. I’ve been driving nothing but stick for 25 years but occasionally I stall in traffic. Not often, but it happens. To everyone. And anyone who owns a stick for everyday driving and tells you they haven’t stalled once since they began to learn, even if they’ve been driving stick for 40 years, is lying. Having driven stick that long, when I do stall, I know what happens before it happens so I almost instinctively punch the clutch without touching the brake, to restart and the car and it has a little forward momentum, about 2-3 mph. Traffic behind you will start to roll. You can start it on that roll then you’re off with no problems. But when I have to slam on the brake, and they don’t know why nor should they be expected to, I cringe!!!!!!! It’s a quirk the engineers never thought of in R&D when they were testing the car I can guarantee you.
#4 | |
This is where WAMS may come through for you, because they can change actual BCM module code, unlock features or port them from another model/trim, I'm just not sure if they can modify these safety aspects. Btw although I have the A8 in my Camaro, I also stalled the stick diesel beater I had to borrow the other day, thinking it'd have more torque off the line. Learned it didn't, and gave it a bit more gas from then on, probably happens to everyone once in a while.
![]() Drives: 2SS M6 Hot Wheels #515 Join Date: May 2020
I taught myself stick when I was 21 (about 30+ years ago) and having been driving on and off ever since. I have been daily on one for the last 2 years. Rarely, but every now and then for any number of dumb reasons I stall the car. Definitely going to happen.
Rotofab, Soler 87mm ported TB, Kooks headers / green cats, MSD wires, flex fuel
Stock intake (no porting) and stock NPP exhaust. Last edited by knighti2; 07-27-2024 at 04:47 PM. |
#6 | |
![]() Drives: 6th Gen LT1 Join Date: Jun 2023
The other problem is the brake light, it can run of hyd pressure or switch. If it is the switch, It would be really hard to bypass it, since you require a lot of other conditions to modify this logic. To reverse engineer this you need to do some testing. Im sure if you're doing over 20 or 30 mph it should bypass itself. |
#7 | |
I was wondering if enabling developer mode and a usb stick will work for the install. |
#8 | |
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
I have been driving manuals for 45 years and sure I have stalled them too. Currently all 3 of my vehicles are manuals which I have had instances of stalling in traffic including my ZL1 until I got adjusted to the clutch but never would I think of reverse engineering it like you stated. Of course it’s your Camaro to do what you want to do to it. Good luck.
#10 |
![]() Drives: 2023 ZL1 M6, 2010 SS M6 Join Date: Oct 2009
I'm risking a negative contribution to the conversation here - and it's not O.T. to the topic of software, and will not be driving for a while to test again myself; but . . . have you tested stalling while still moving? I'll try next time I'm driving.
Stall-stop-brake - fine. I vaguely recall doing one of those stalls where you're still kind of rolling and starting with just the clutch and button. I may be remembering it wrong, maybe I nervously touched or hit the brake; but maybe I didn't. I'm just asking - or suggesting - is the brake requirement just there for a fully stopped car? |
#11 | |
Trust me - I’ve tried starting with the clutch pedal down, no brake, while the car is rolling and you get the message and car will not start.
#12 |
![]() Drives: 2023 Camaro 1SS 1LE 6MT Join Date: Nov 2023
I've stalled my Camaro twice. Once when I first drove it because I was used to my old Trans Am, and again not too long ago, just something stupid at a stop sign. It happens, I've only had it a year so that's probably about average.
Thankfully neither at a point where having to also apply to brake was an issue. Now that you mention it though I could totally see that, and that does sound like a pain! It is a safety hazard I'd say. Does it start if you just apply the brake slightly? (Hopefully minimizing actual braking) On a somewhat related note, can you "push start" these cars? |
#13 | |
I might work on that at some point. If i get a GMLAN sniffer you can display some cool data and maybe write some. |
#14 | |
Now that being said, our cars should be able to push start. It would be ridiculous that if the engine stalls in the highway doing 60, you have to stop completely and crank. Having to apply pressure on the brakes is also ridiculous. Has anyone tried to clear a flood in the engine? Pressing the gas pedal 100% and then cranking? It would be weird to have to press all 3 pedals at the same time. |
