Old 07-25-2024, 08:51 PM   #1
ZLRob
Super Stock
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
Quick question: stock tuning at idle
What is it supposed to be? I've been having some issues dialing in a 91mm effective Soler TB and I'm finally getting to a point where it is pretty stable but I'm only seeing 19-22 degrees at idle. Is it supposed to be higher? I'm pretty sure it was supposed to be in the 30's but I can't remember. Thanks in advance!
2017 Red Hot ZL1 A10 - Apex ARC-8's, 305/ 325 PS4's, DSX 9.06 12% lower, Griptec 2.5 upper, NGK HR7 Ruthenium plugs, Nostrum 22+ injectors, XDI Goliath HPFP, Katech dual in tank low side pump, Katech oil pump, LME tensioner, DOD delete, LT1 big fuel cam, Jokerz ported blower, MPI lid, GMS hood extractor bracket, Soler ported 87mm (91mm eff) TB, Granatelli SS plug wires, Cordes LTR reservoir, DMS T-stat housing, 186* LS3 T-stat, Black Widow Angry Housewife/ Corsa NPP mufflers, Borla X pipe, BMR engine mounts, Banks iDash, Lithium Battery, AEM X- Series, HP Tuners, E85, 16.5 psi
834 HP/ 840 TQ
Old 07-25-2024, 09:18 PM   #2
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
That’s more than I get lol…doesn’t sound bad to me.
Old 07-25-2024, 09:25 PM   #3
ZLRob
Super Stock
ZLRob's Avatar
Lol, alright brother, thank you! I should probably consult with the high octane map as well because I'm trying to get close to what it's supposed to be I just don't remember what the heck it was. VTT tuning is mad annoying.
834 HP/ 840 TQ
Old 07-25-2024, 09:46 PM   #4
JSH
JSH's Avatar
Drives: '20 ZLE
15 seconds after startup on my OEM block it had 32
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO.
15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR.
100 octane: 1045hp/1055tq.
100 octane + Alky MAF Meth (1) 10+:
Old 07-25-2024, 10:11 PM   #5
Joshinator99
Moderator
What does your commanded/actual torque at idle look like?
Old 07-25-2024, 11:38 PM   #6
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
I feel like an actual idle spark in the 15-20 range is ideal, definitely not in the 30s in my opinion.
Mods being installed-
Old 07-25-2024, 11:42 PM   #7
ZLRob
Super Stock
ZLRob's Avatar
Very much appreciate the input gents!
I haven't looked at commanded/ actual with super deep interest, but that is something I'll have to look at here in a second. I finally got my torque management to stop jerking me around at part throttles and got several issues patched up that required utilizing user defined values. Semi pricey spend to be able to define and access those values but it was totally worth it. Car drives awesome now but I feel like DD tables could use some mild clean up in the part throttle sections. Especially at zero pedal.
Joshinator: I just realized I'm not logging immediate engine TQ command, but I have been logging predicted engine TQ command so I'm going to have to take a log of that and get back to you. I thought I was but there are so many freaking PIDS available to log so it's easy to miss one.
834 HP/ 840 TQ
Old 07-26-2024, 06:23 AM   #8
Joshinator99
Moderator
Maybe KingLT1 or Megahurtz will chime in too…they do this way more often.
Old 07-26-2024, 07:52 AM   #9
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
What does your MAF error show at around those cells in the curve? How much TMA do you show in the Scanner at idle? I've heard some say you want to see some TMA - maybe 5-10* so there is still room for it to control timing. You definitely don't want negative timing, or you'll be burning up cats'. Part of it could be in your Virtual Torque. A higher flowing TB could be indicating too much airflow to the ECM, and it could be pulling timing as a result. Making adjustments, at commanded timing, at that cam angle, could help with this. I'd log and look at ZERO PEDAL TQ, too, and make adjustments from there, if necessary. It should be close to ZERO. I'd, first, make sure the airflow model is correct.
JMHO.
'20 ZL1 Black "Fury"
Old 07-26-2024, 10:07 AM   #10
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Your idle timing should be in the 10-20 degree range, but you want your zero pedal torque around 0 at idle.
Old 07-26-2024, 10:41 AM   #11
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
zero pedal torque at idle needs to be positive, recommend 0 to 10°, i usually run it around 5°
Old 07-26-2024, 02:35 PM   #12
ZLRob
Super Stock
ZLRob's Avatar
JMHO.
I am seeing around -6 to -12 at idle. All this virtual torque stuff is mind melting just to restore proper drivability. Maybe the Soler TB was a bad idea. I do think that my airflow model has been off for a while though, definitely even before I put it on. I think this just sort of exacerbated an issue that was already there.
834 HP/ 840 TQ
Old 07-26-2024, 05:47 PM   #13
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
When i see something like negative timing at idle I would probably get fueling ok and then go look at zero pedal torque as compared to delivered engine torque. If you see negative timing your engine torque is likely higher than your zero pedal engine torque. Go look at virtual torque tables at the RPM/timing°/airmass and MAP values and massage up that part of the two tables equally till it is closer to the engine torque value. This will stop causing it to pull timing. You should land somewhere between 0 to 15° positive.
This video is a good example of how to do this:
You may also want to look at your \\engine\airflow\electronic throttle tab and confirm you have changes the max area for the larger TB.
Old 07-26-2024, 07:08 PM   #14
KingLT1
KingLT1's Avatar
Easy solution is to get rid of the soler throttle body and go with a stock LT5. Not the first time I have seen this happen with those...and that was after swapping a NW 103 that was tuned for a Soler 107. Made timing go so far negative that I didn't even want to attempt to correct it in the VTT. But if you want to try and make it work, you need to go into the VTT, uncheck the boxes that applies changes to all, and remove torque in the idle region .20-.30 airmass/ 4-800rpm area and interpolate around that spot for the -10, 0, 10 degree tables. I would remove 20ft lbs at a time until timing gets around 10-15 degrees. If you pull too much torque it will start to act funky. Honestly anything above +5 degrees with a 0-15 zero pedal torque is probably fine.
