Old 07-18-2024, 10:52 AM   #1
1supersport
Drives: 2023 Camaro 1SS
AFM & NPP exhaust valves
I've come to realize the squeaking exhaust valves are a common issue on the Camaros. I've owned 2 brand new Camaros, LT1 2021 and my current SS 2023. Both had chirping noises coming from these valves. The issues for BOTH started after a month of owning the cars, not even 1,000 miles on them. I'm reaching 10,000 miles on my current SS and just dealing with the chirping, but it is very annoying.
I have a few questions and potential recommendations for others with the issue.
1. Is there any aftermarket exhaust system that works better than the stock, removing this issue all together?
2. It seems like replacing the exhaust system under warranty with new stock one isn't worth it since many have said the issue returns. Not sure if anyone has had any luck here?
I'll link an image of where the valves are located. Flange set #1 are AFM and flange set #2 are NPP. https://imgur.com/3GjQK8k
There's also TSB #16-NA-003 which I'll attach a link to as well. https://static.nhtsa.gov/odi/tsbs/20...34535-9999.pdf
Very annoying this issue has been ongoing since at least the 2016 models. Seems like an inherent design flaw on GM's end.
1supersport is offline   Reply With Quote
Old 07-18-2024, 11:05 AM   #2
Zapote21
Tampa Bay Camaros
Zapote21's Avatar
Drives: 2017 Krypton Green 2SS
I use a range device always so the AFM valves are a no issue. Also, did an axle back exhaust so my NPP valves are off to the side and not functional.
But I dont remember any squeaking when I had them operational on any of my Camaros
Me and wife, in order
2011 2SS SGM
2013 2SS Hot wheels vert
2016 C7 DSOM
2012 2SS yellow vert
2017 2LT Krypton Green
2018 2LT Hot wheels crush
2020 2SS Shock vert.
2017 2SS Krypton Green coupe
Zapote21 is offline   Reply With Quote
Old 07-18-2024, 11:10 AM   #3
1supersport
TSB #16-NA-003 says temperature and humidity related. I am in Florida and noticed others with the issue posting from Florida, but also a few from Cali which I know is a lot dryer.
Old 07-18-2024, 11:32 AM   #4
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Get a Range AFM Disabler and pull the NPP fuse (NPP valves will remain full open all the time). Easy and cheap fix and easily reversible.
Old 07-18-2024, 11:34 AM   #5
SSShark
SSShark's Avatar
Drives: '23 1SS Sharkskin A10
Easiest solution is to buy the Range AFM disabler. My valves were noisy, but since installing the Range, no noise.
SSShark is offline   Reply With Quote
Old 07-18-2024, 11:35 AM   #6
1supersport
How do I make sure valves are open before fuse is pulled? And I heard range devices can trigger CEL. It is common or rare?
Old 07-18-2024, 12:36 PM   #7
RideWithDanger
RideWithDanger's Avatar
Drives: 23 2SS 1LE
Just a heads up for the people saying to just pull the fuse or get a range disabler, my last Camaro had this exact issue and I made a video on it: https://youtu.be/QmqrQ1xk9Ho
But my car had the AFM system tuned out, and no NPP, and still had the rattle. If the AFM valves are the ones rattling, which mine were, then disabling it won't actually do anything because they rattle and squeak in the open position. Maybe some people here have had luck with just disabling it but that was not the case for me. My rattle didn't even start until long after it was tuned out.
You have a few options on what you can do. Option 1. You can disable the AFM system and also remove the valves. A catback will do this, and I highly recommend AWE Touring system if you do this. Option 2. AWE also sells valve simulators so you don't even have to tune out AFM or get a range device, just hook the valves up to the simulators. Option 3. You can weld the AFM valves open if you want to keep your stock exhaust.
Instagram: RideWithDanger
Current Mods: Rotofab, Ported LT2 intake, LT5 TB, Kooks Headers, AWE Touring Catback
Radiant Red 23' 2SS 1LE
1100: 11/14/22 | BUILT: 3/16/23
2000: 2/17/23 | 4200: 5/8/23
3000: 2/27/23 | 5000/6000: 5/15/23
RideWithDanger is offline   Reply With Quote
Old 07-18-2024, 12:53 PM   #8
SomeGeoffGuy
SomeGeoffGuy's Avatar
Drives: 2023 2SS Convertible
The rattle and the squeak are two different issues! My 2016 had both. My 2023 has neither (so far!). The dealer had some different repairs for the rattle - some with epoxy and the one where you trim the ears off the gear assembly.
-Geoff
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold!
'23 2SS Convertible -Same as above except orange.
SomeGeoffGuy is offline   Reply With Quote
Old 07-19-2024, 01:06 AM   #9
2SS Capt
2SS Capt's Avatar
No CEL on the Range, the valves are spring loaded to the open position, so no power, they are open, pull the fuse, they stay open... My fuse has been pulled for 2+ years along with a Range device even longer than that...
Old 10-17-2024, 07:03 PM   #10
gkitab241
gkitab241's Avatar
Drives: 2023 Camaro SS2
I'm new to the forums so excuse me if I'm doing this wrong. Lol.
So I have done new cat back and afm valves on my 23 ss are in the trunk. Found it leads to cel. Clear the code but it comes back on start up. Plug valves in and ECU is satisfied. I know they can be tied up and know the have the simulators then will keep them mounted up and away. I have heard that the vettes have dummy plugs which are a nice option to satisfy. But haven't been able to find the for Camaro.
Does anyone know of any or if the vette afm/npp dummy plugs module will work?
gkitab241 is offline   Reply With Quote
