Old 07-13-2024, 04:47 PM   #1
Saberscar223
Saberscar223's Avatar
Drives: 2023 Riverside Blue 2SS
BTR 225 on 10 Speed SS Stock Converter
BTR 225 on 10 Speed SS stock converter
E85, CAI, and ported heads and the Exhaust Setup is 2inch KOOKS,stock mid pipe, Flowmaster American Thunder Axel backs with NPP.
Don’t see many people talk about this setup so I thought I’d share my experience.
Drives perfectly fine on the stock converter, jerks a tiny bit when slowing down but it’s barely worth mentioning and if you’re deciding between a stage 1 or 2 for drivability on a 10 speed get the stage 2 you won’t regret it.
Low to mid range is practically the same as it was before the Heads and Cam but top end is DRASTICALLY better.
Was dynod but it was over 100 degrees and the tuner only had one small fan on the car. Only made 464 whp but it’s definitely much higher than that.
I’m still running the stock Intake manifold and throttle body but that’s next on my list. Between the Lt2 and the Msd right now.
Sound clip: https://youtube.com/shorts/3kNPAX-6_...35HYXD4zJ0DADa
Saberscar223 is offline   Reply With Quote
Old 07-13-2024, 05:44 PM   #2
Germansheperd1
Germansheperd1's Avatar
Drives: 2024 LT1
1/4mi times?
Germansheperd1 is offline   Reply With Quote
Old 07-13-2024, 05:53 PM   #3
Saberscar223
Haven’t gotten the chance to track it yet.
Old 07-13-2024, 10:43 PM   #4
KC64
Gray Ghost
KC64's Avatar
Drives: 24 Camaro 2SS Loaded
Sounds very nice!!
Did you do the VVT Delete also?
KC64 is offline   Reply With Quote
Old 07-14-2024, 04:30 AM   #5
Saberscar223
Originally Posted by KC64 View Post
Sounds very nice!!
It came with a 4 degree VVT limiter
Old 07-14-2024, 08:14 AM   #6
Germansheperd1
Drives: 2024 LT1
Time slip before the mods?
Old 07-14-2024, 12:50 PM   #7
7speed
Drives: 21 SS
How the inside idle? I don't care for being rocked to hard inside the cabin
FBO, E85
11.1@123
7speed is offline   Reply With Quote
Old 07-14-2024, 01:39 PM   #8
Saberscar223
It shakes a little but it makes me smile haha. Nothing crazy.
Old 07-14-2024, 01:44 PM   #9
wang970305
Drives: 2021 Camaro 2SS
you can get a dragy to test all the timers on the road... i have mine for sale lol
I think you should get MSD instead of LT2 since its cammed
2021 Camaro 2SS Summit White
Kooks 1-7/8'' LTH with high flow cats, Corsa Catback Exhaust, Roto-Fab CAI, Ported LT2 IM, LT5 95mm TB, Lethal Garage Flex Fuel Sensor, Mishimoto catch can, AEM Wideband.
wang970305 is online now   Reply With Quote
Old 07-15-2024, 10:02 AM   #10
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
MSD will get you higher RPM's on the high end for sure. LT2 not as much, but my shifts are tuned for 6800-7100 rpms on the LT2. But my power band starts at 6300 soo. It will likely be different for the OP.
Old 07-15-2024, 10:04 AM   #11
FlukeSS
FlukeSS's Avatar
That Jerkiness you are feeling is because of the Torque Converter. Specifically the lock and unlock patterns, which can be changed in the tune. I had to have mine changed as well. My cam is a 220 cam so just a touch smaller than yours. Made it a easier on the street especially at low speed.
Old 02-10-2025, 11:44 AM   #12
Saberscar223
A question for you, my car is tuned to shift higher but it still looks like it shifts at normal RPS according to the gauge, does yours show a difference and move past redline?
