Old 07-13-2024, 03:07 PM   #1
Sephx1
Sephx1's Avatar
Drives: 18 ZLE, 18 SS1LE, 16 SS, 23 ZL1
Big discrepancy between Aeroforce gauge and dash gauge coolant temps
Dash Gauge says nothing to see here all is well - but Aeroforce plugged into OBD tells a different story. Car is cammed with headers and pulley. Also has an aluminum thermostat housing. Hot here in Phoenix but shouldn’t be running this warm just cruising.
Sephx1 is offline   Reply With Quote
Old 07-13-2024, 03:24 PM   #2
Patriot Motorsports USA
Patriot Motorsports USA's Avatar
Drives: 2021 ZLE, C5 Z06 6.0L Procharged
Just get a Banks iDash Datamonster. You can program 1-6 different values to disply, comes with a micro-SD card slot for datalogging and it will show every parameter including E-Content as well as many more you'd have to dig into HPTuners to find.
Best of all... if gives you a screenshot any time a soft or hard code hits with a complete datalog automatically. You can also upfit it to rear analog as well as any other remote sensor data you wish.
Patriot Motorsports USA is offline   Reply With Quote
Old 07-13-2024, 03:57 PM   #3
Rapid_blue_zl1_22
See you at the Track!
Rapid_blue_zl1_22's Avatar
Drives: 2022 Rapid Blue SS 1LE
To my understanding, the dash value isn't the actual sensor data, but a calculation based on other variables. The value on the AeroForce is the actual sensor data.
Edit: I guess I should say, dummy gauge. It is like a good/bad indication, not a real value. I could be wrong.
2022 M6 Rapid Blue 1SS 1LE PDR (Current)
2022 M6 Rapid Blue ZL1 (SOLD)
Rapid_blue_zl1_22 is offline   Reply With Quote
Old 07-13-2024, 04:08 PM   #4
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
I think the Aeroforce is suspect. When my dash gauge is in that area (normal operating temp) hptuners datalogs match, showing anywhere from mid-180s to mid-190s
Mods being installed-
Old 07-13-2024, 04:27 PM   #5
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Can’t say for sure that the Aeroforce is correct but can say the dash gauge is rubbish.
Old 07-13-2024, 07:51 PM   #6
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
What were you engine oil temps at the time?
Old 07-14-2024, 04:08 PM   #7
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Dash gauge is not too useful. Even with Scanner commanding about 190, and reading 190, the dash doesn’t move much.
I have yet to run the Aeroforce but it’s running off the CAN, no? So shouldn’t it be displaying what the ECM is using?
'20 ZL1 Black "Fury"
Old 07-14-2024, 09:37 PM   #8
Idaho2018GTPremium
Idaho2018GTPremium's Avatar
Drives: 2021 Camaro ZL1 A10
I've read from vehicle engineers that modern coolant gauges are intentionally slow to respond and don't respond to short peaks as to not constantly alarm or cause concern to the drivers. I wish they were a bit more accurate. My coolant gauge stays at the same spot practically all the time no matter how I'm driving and the outside temp. The oil temp gauge moves around more and will show higher temps if I drive it harder, but the coolant gauge stays put.
2021 Camaro ZL1 A10
2022 GR Supra 3.0
Past:
2018 Mustang GT Premium w/ PP1, MR, and A10
2007 MazdaSpeed3
1995 Pontiac Trans Am
1987 Camaro Z28
Idaho2018GTPremium is offline   Reply With Quote
Old 07-15-2024, 01:16 AM   #9
Once the coolant has reached operating temperature, the thermostat should regulate it to a near constant temp, so the gauge not moving much doesn't surprise me. Guess the programming is done in a way that hides smaller fluctuations while the thermostat opens and closes periodically.
If the cooling system can no longer cope with the thermal load, the gauge will probably start creeping upwards. (I say "probably" because that hasn't happened to me yet.)
Old 07-15-2024, 01:46 AM   #10
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
230F seems high for around town driving. A few questions if I may...
1. what thermostat you are running?
2. Do you have HP Tuners?
3. Are you running the stock fan settings?
Old 07-15-2024, 04:11 AM   #11
Kamero6
Drives: 6th Gen LT1
The camaro should fallow what most manufacturers do.
Temp gauge starts at the bottom. 80F is the first line usually.
180F is operating temp. They always show 10% less than half the gauge to psicologically make you think the engine is cold (people think about cold and hot as their body temp / feeling, nobody has automotive knowledge anymore).
After 235/240F the gauge starts to creep at a different ratio that is does from 32 to 180.
250f might be 3/4 and 260 100%.
then the gauge is dead from 180 to 240.
I understand the engineers. Back in the time and analog gauges were hard to trick like this. That's why we hear "that model used to run hot" and nobody says that anymore.
Last time OEM's made that mistake was with the C4 corvette. The coolant temp gauge goes to 3/4 all the time and the car is know for "overheating" when in reality is supposed to work at that temp.
Kamero6 is offline   Reply With Quote
