Old 07-11-2024, 05:01 PM   #1
retmil
Drives: 2022 Wild Cherry SS
How to Reset the "Change engine oil" Msg
Would someone please explain how to reset the "change engine oil" msg? I have tried numerous suggestions including the one in the owners manual and still getting the msg on dash. TIA!
retmil is offline   Reply With Quote
Old 07-11-2024, 08:02 PM   #2
roostere4
Drives: 1987 IROC, 2020 ZL1
which procedure did you use, there are 2 in my owner's manual. You might need to try the other one.
Option 1
Code:
1. Display the REMAINING OIL
LIFE on the DIC. See Driver
Information Center (DIC) 0 117.
2. Press and hold SEL on the DIC
while the Oil Life display is
active. The oil life will change
to 100%.
Option 2
Code:
2. Fully press and release the
accelerator pedal three times
within five seconds.
This may need to repeated one or more times
The system is reset when the
CHANGE ENGINE OIL SOON
message goes off.
If the CHANGE ENGINE OIL SOON
message comes back on when the
vehicle is started, the engine oil life
system has not been reset. Repeat
the procedure.
Another option is if you have a OBD scan tool, you should check the special functions. A lot of the tools have an option not just to reset the oil life but also to set it to any particular value you want.
I did this myself, reset it to 15% so to remove the warning when I had scheduled the oil change, but didn't want to fully reset it.
roostere4 is offline   Reply With Quote
Old 07-13-2024, 04:26 PM   #3
retmil
Oil Life Reset
Thank you for the info but still can't reset the light so going to get my friend to reset it with his scan tool.
Old 07-18-2024, 09:45 PM   #4
dpevans
Drives: 2024 Riverside Blue 2SS 1LE
Bring up your oil life, right arrow it will ask to reset, it will say no, scroll up and and it will say yes then hit enter.
dpevans is offline   Reply With Quote
