Old 07-09-2024, 12:38 AM   #1
Baddawg53
Drives: 17 hyper blue 2SS M6
Rear main seal - install dry or wet?
As the title says, are these seals meant to be installed dry, or a light film of oil on the crank? I can't seem to find any info.
Baddawg53 is offline   Reply With Quote
Old 07-09-2024, 01:36 AM   #2
Tim M
Tim M's Avatar
Drives: 2018 Camaro SS 1LE
I used a light coating of oil on my installation. No leaks noted. It is slides across the crank so...
Tim M is offline   Reply With Quote
Old 07-09-2024, 08:36 AM   #3
Baddawg53
The light coating seems like it would be the better way, thanks.
Old 07-09-2024, 10:15 AM   #4
GreyGhost702
Drives: 2019 Camaro 1SS1LE
Just did both front/rear seals. Just to be specific, the cover to seal install should always be 100% clean/dry. The seal to crank/pulley I've done both ways on previous vehicles and never had one fail/leak done dry or wet. But I used a finger dab of clean oil on this build.
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane
7/26/2024 Tuning in progress
GreyGhost702 is offline   Reply With Quote
Old 07-09-2024, 10:35 AM   #5
Baddawg53
I was taught way back in the day to always lube seals with what they're sealing.
Old 07-09-2024, 11:50 AM   #6
GreyGhost702
Same. But in regard to the seal install to the cover, it's a machined fitment for the seal itself, lubricating this fitment could reduce the hold on the seal. But I assume you're meaning the seal against the crank end that turns, which I agree, I like to do a wet seal, just a finger dab of oil. Again, just did this myself last week.
Old 07-09-2024, 12:49 PM   #7
Baddawg53
Yes, exactly, the seal to the crank not the seal to the housing. I just did this too, ended up with a massive oil leak. I think I messed up the housing to block seal where it meets the pan, tons of oil everywhere so kinda tough to tell.
Old 07-09-2024, 01:57 PM   #8
GreyGhost702
That's the one thing I'm worried about, as well. The whole engine is essentially just RTV sealed. I much prefer a rubberized plastic gasket on the oil pan. On the Mustang's back in the SN95 and S197 days it was like this and you just needed a dab of RTV where the covers and pan met the gasket.
I was very careful to keep the RTV bead thickness to what the manual called for and where it was supposed to go... I really hope that shit doesn't leak. Dropping the pan really isn't an option to me, the whole ****in thing would have to come out. Not gonna struggle on back to try and peel that oil pan off under the car. It was a job just to remove the pan the first time without marring up surfaces. I ended up using a plastic putty knife and plastic razor blades. It would have been a nightmare to remove with the engine in. Unless you can drop the cradle completely out of the way. Not really optimal without a lift.
Old 07-09-2024, 04:14 PM   #9
Baddawg53
Yea, I've gotten super good at taking the engine out. Only took me 4 hours on Sunday. Hopefully I never have to do it again.
I'm replacing everything this time, pan, seal housing and seal. I don't think anything is wrong with them but I'm tired of taking the engine out
Old 07-10-2024, 11:53 AM   #10
GreyGhost702
My build has made me want to gouge out GM engineers eyeballs more than usual. I think resto-mod may be my next thing, lol.
