Old 07-06-2024, 02:29 PM   #1
19Nasty1le
Craig
19Nasty1le's Avatar
Drives: 2019 ZL1 1LE
Ported blower stock tune?
Has anyone ran a ported LT4 (non blackwing different ECM i guess) on stock tune? Curious if i can port my blower now and keep a 2.5" pulley (OEM size) and drive it without issues until i do the rest of my mods and tune it. Been getting Yes and No answers from different sources. CSP might actually do a video on this after talking to Andrew. Currently only have a RotoFab Dry and Corsa Extreme+ catback
19Nasty1le is offline   Reply With Quote
Old 07-06-2024, 08:17 PM   #2
Rapid_blue_zl1_22
See you at the Track!
Rapid_blue_zl1_22's Avatar
Drives: 2022 Rapid Blue SS 1LE
Yes, you can. These cars run a little on the rich side stock, so they can handle a little extra air. I ran my Kong X-port for almost a year with no tune (Stock pulley size). Not only is it doable, but the car ran phenomenal.
I didn't dyno it, but it felt stronger, and the whine was amazing. I track my car on road course, so it wasn't driven softly for that year. I installed a wideband gauge whenever I did it because I had my concerns as well, but Lambda was perfect. My car is tuned now, but at the time it was 100% stock besides the X-Port and Corsa intake/axleback exhaust.
2022 M6 Rapid Blue 1SS 1LE PDR (Current)
2022 M6 Rapid Blue ZL1 (SOLD)
Rapid_blue_zl1_22 is offline   Reply With Quote
Old 07-07-2024, 03:54 PM   #3
19Nasty1le
Craig
19Nasty1le's Avatar
Awesome info thank you! I don’t have a wideband and was worried about this as I was told the DI engines are ok lean but rich can damage apparently? I’ve been told yes by the manufacture companies and no by tuners lol. Jokerz has the porting on sale plus a discount for July 4 so wanted to grab it while I could!
Old 07-07-2024, 04:21 PM   #4
Z OH 6
Drives: 2021 Red Hot ZL1
Somewhat rich isn't likely to damage anything. That being said, forced inductions engines need to be richer than NA engines.
Old 07-07-2024, 08:14 PM   #5
Rapid_blue_zl1_22
There is a big difference between optimized and safe. Tuners say no because it is not optimized to make max power possible, but that doesn't mean it isn't safe. They just want you to spend $1k on their tune.
Lean is bad, a little rich is ok. These cars run pretty rich from the factory, so leaning them out a bit is still fine.
Old 07-08-2024, 09:49 AM   #6
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Imo ZL1's don't run rich. They target 12.4 afr on a gas scale.
The only vehicles that I would run the stock tune on with modifications are cars with factory widebands that can self-correct.
Another friendly reminder since this hasn't been mentioned for a while is that these ECU's are torque based with preset torque limits in place. You start trying to add power and the ECU will close throttle in attempt to keep torque under its programmed limit unless you adjust this in the tune.
Old 07-08-2024, 07:42 PM   #7
19Nasty1le
Craig
19Nasty1le's Avatar
I’ll be keeping OEM size pulley on it, and won’t be driving it much / beating on it until I get to my tuner to get Cam Headers etc installed just getting the lead time on the porting out of the way. Gonna grab up a DSX lid too I think
Old 07-08-2024, 07:58 PM   #8
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
If you are minimizing driving and keeping your toe out of the throttle I doubt you will have a problem. But absent a tune, your car wont be able to efficiently use the increased air flow from the porting. Since this is a temporary measure, that is not a concern I’d guess.
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 07-09-2024, 08:19 AM   #9
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Aren't they known to do this, even with a standard RF, for example?
'20 ZL1 Black "Fury"
Old 07-09-2024, 08:59 AM   #10
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
The car won't blow up without a tune. But you won't be making the best use of the extra air without a tune. The car will feel sluggish in the lower RPM range.
GM Gen V Calibrator
