Old 06-27-2024, 07:16 AM   #1
Ss7617
Drives: Chevy z06
eLSD issue zle
I have a 18 zle. When on track and after the first session the diff starts shuttering or chattering on left turns only. 6m car. Car has 8k miles and 4 diff oil changes w factory oil. I just changed it and went to track with same issue. Any thoughts?
Thanks scott
Ss7617 is offline   Reply With Quote
Old 06-27-2024, 11:00 AM   #2
dmcmahan60
dmcmahan60's Avatar
Drives: 2017 SS
What color was the fluid every time you changed it?
dmcmahan60 is offline   Reply With Quote
Old 06-27-2024, 12:37 PM   #3
Ss7617
Drives: Chevy z06
Last 2 it looked fine. I’m gonna change again this week and see how it looks
Old 06-27-2024, 12:50 PM   #4
GreenZLE
Drives: 2020 Rally Green ZL1-1LE
The eLSD clutch packs dont circulate gear lube, they have a sealed unit that circulates transmission fluid.
GreenZLE is offline   Reply With Quote
Old 06-27-2024, 01:17 PM   #5
Ss7617
Drives: Chevy z06
I thought the cutch packs were in the gear oil. And the atf fluid just pushed the sealed pistons on gear pack?
Old 06-27-2024, 01:30 PM   #6
GreenZLE
I thought the same thing and always changed my gear lube with the GM lube with friction modifier. There has been several threads about this on Camaro 6. The last one I looked at had a picture of the sealed unit with splines that engage the axle.
Hopefully someone can chime in to confirm or deny.
Old 06-27-2024, 07:49 PM   #7
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
This is correct: the clutch packs sit in gear lube like any other passive clutch LSD, and it's the same fluid that also bathes the gears. The hydraulics that actuate the force on the clutch packs are completely sealed and separate from the rest of the diff. You have to make sure you are using the proper GM 88862624 diff fluid. It already has friction modifier in it and does not need anything added.
I can't come up with an explanation for why your car only chatters on left turns when the diff gets hot. In that scenario, the left side is turning slower than the right, but that doesn't really explain anything. Are you 100% it's the diff chattering and not a wheel bearing or CV joint?
Matt Miller
2020 SS 1LE
Msquared is offline   Reply With Quote
Old 06-27-2024, 08:12 PM   #8
Ss7617
Drives: Chevy z06
I’m using the factory Druid with the modifier in it. I guess I can’t say 100% it’s the diff,but I’m pretty sure it is. It feels like it binds and unbinds only after it’s really warm. First session of track day it’s fine. Can’t replicate on street.
Old 06-27-2024, 09:13 PM   #9
dpevans
Drives: 2024 Riverside Blue 2SS 1LE
My question is reading these forums is I believe there is a software update for the eLDS.
dpevans is offline   Reply With Quote
Old 06-27-2024, 09:54 PM   #10
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
Since you're using factory fluid and assuming it's not low, it sounds like something happened to the clutches in the diff but you never know without a thorough investigation. Maybe an axle, but I can't think of much else that would make the car behave that way.
For better or worse, there's lots of ZLE parts for sale used if you need something.
Old 06-27-2024, 11:00 PM   #11
Msquared
Msquared's Avatar
It's a firmware update for the module that controls the diff. However, it has nothing to do with fixing chatter, and it only affects the timing and rate of locking when all nannies are turned off and your below about 80mph. Therefore, it's not like to change much about the diff's track behavior. It was intended to improve its function for autocross use, and it succeeded at that.
Matt Miller
2020 SS 1LE
Old 07-06-2024, 11:56 AM   #12
NickyRacerBoy
Drives: 1LE
Thanks scott
Hey Scott I have a spare ESLD with module for sale.
NickyRacerBoy is offline   Reply With Quote
Old 07-06-2024, 04:55 PM   #13
AZIROC
Drives: '86 IROC-Z '18 ZL1
I had the same issue....ended up putting some SPL toe links on and that helped alot.
Old 07-12-2024, 07:54 AM   #14
Patriot Motorsports USA
Patriot Motorsports USA's Avatar
Drives: 2021 ZLE, C5 Z06 6.0L Procharged
Cool
Thanks scott
For one... I only use Amsoil on my ZLE A10 and I change the fluid pretty much before each two-day track weekend (it helps having a lift, shop and a pump mounted to a 5-gallon pail full of the stuff...). In all of my abusive 13k track & mountain road driving with 20K total miles... I have never had the rear end chatter.
The ATF going through the eLSD is coming from the transmission, being pumped from your M6, to the engine's cooling radiator, then down to and across the lower Aux Heat Exchanger (LAHX) before it makes the long really hot trip past the header/cats/tunnel to the eLSD to do more work, BEFORE going back to the transmission.
SO... if your using the Mobil1 or GM fluid for this and that fluid is OLD, it already starts out weaker than quality hydraulic fluid and could be causing the issues you are experiencing. My suggestion is switching to the Amsoil Signature Series fluid. Changing fluid alone will improve shifting as well as lower it's operating temps with greater hydraulic compressibility for the eLSD. I think this will solve your issues.
Patriot Motorsports USA is offline   Reply With Quote
