Old 06-25-2024, 10:08 AM   #1
Malice
Drives: 2022 Camaro 2SS 1LE M6
Rear Tow hook
Has anyone installed a rear tow hook or tow strap? Where did you mount it? Got pics?
2022 2SS 1LE M6 - 100% factory stock
https://www.youtube.com/@GeoffPalmer83
Malice is offline   Reply With Quote
Old 06-25-2024, 10:26 AM   #2
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
Here is one thread with pictures. There may be other threads if you search.
https://www.camaro6.com/forums/showthread.php?t=546979
Old 06-25-2024, 11:40 PM   #3
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
Not even sure what you are asking.
Are you asking about a receiver?
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
Old 06-26-2024, 10:25 AM   #4
Badmojo
aka BeastZL1
Badmojo's Avatar
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Old 06-26-2024, 10:31 AM   #5
Badmojo
aka BeastZL1
Badmojo's Avatar
I recently did one on my 19 ZL1 1LE located behind the license plate.
2019 Camaro ZL1 1LE
Old 06-26-2024, 12:28 PM   #6
Baddawg53
Drives: 17 hyper blue 2SS M6
I'm about to install a rear tow hook, hopefully next week. Doesn't seem too complicated.
Baddawg53 is offline   Reply With Quote
Old 06-26-2024, 01:32 PM   #7
Badmojo
aka BeastZL1
Badmojo's Avatar
The complicated parts are:
1. Not tearing off the spacer between the tail lights. Pull straight back, not up.
2. Choosing a location that does not interfere with a wiring harness or airbag sensor.
3. Creating a good point of reference for drilling the bumper cover. I suggest using the bumper centerline and the ground.
4. Not scratching the bumper with multiple on/offs for measurement. I suggest using a body panel work stand like this one from Eastwood. Take your time and a second set of hands is helpful.
Link to padded workstand:
https://www.eastwood.com/750lb-work-stand.html
2019 Camaro ZL1 1LE
Old 06-26-2024, 03:44 PM   #8
Baddawg53
Thanks for the tips!
Lining it up to drill the hole in the bumper was the part I was concerned about, ya only get one shot at it. I didn't think about making reference points, that's a great idea.
