Old 06-24-2024, 06:10 PM   #1
Green82
Green82's Avatar
Drives: 2022 camaro 2SS
mods
i have a 2022 LT1 and wanting to start adding performance mods
i can only get 91 octane in my area so what can be added to get the most gains with 91 oct.
Green82 is offline   Reply With Quote
Old 06-24-2024, 06:28 PM   #2
GreyGhost702
Drives: 2019 Camaro 1SS1LE
Almost anything. 91 Octane will support about 800whp or thereabouts. There's also Torco if you need more safety margin and E isn't available. You'll want to narrow down what you want to do to your car a bit. Mild, FBO, wild?
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane
7/26/2024 Tuning in progress
GreyGhost702 is offline   Reply With Quote
Old 06-24-2024, 06:31 PM   #3
Green82
Green82's Avatar
fbo to wild is what i like to do at some point. just not sure what mod to start with
Old 06-24-2024, 06:58 PM   #4
GreyGhost702
The only mods that don't really require tuning will be exhaust related. Such as secondary cat delete, and/or muffler.
Building a car in onesie-twosie fasion isn't efficient. You want to plan your build via budget and/or time. Such as, say you have a $5,000 budget this year, but next year you want to go all out. Plan for what you can do with a $5,000 budget that will be fun and hold you over for the year, but also compliment your build when you go big next year. Or, say you want FBO for about 5 years, and then you want to see what the market is like, if you want to keep the car, ect. Then go big or slip into a ZL1.
If you're wanting to do FBO, what is your goal for Wild? Boost or big cube max effort NA? Spray?
Also, just FYI, shops like GPI/Jannetty/BTR can help you find direction in these things, since it's pretty much what they do all day. Most of 'em will give ya advice even if you aren't having them do the work.
Old 06-24-2024, 10:10 PM   #5
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
E85 is the biggest no brainer. Great for NA bolt on cars and even better if you decide to go forced induction down the road. Looks like Oklahoma has plenty of E85 stations too:
https://afdc.energy.gov/fuels/ethano...arest?fuel=E85
Old 06-24-2024, 10:58 PM   #6
Green82
Green82's Avatar
closest station from me with E85 is about 70+ miles
Old 06-25-2024, 12:02 PM   #7
GreyGhost702
It's not a requirement for any built, but IMO I don't think it hurts to have the E kit installed and turned on. That way if you do get some E, your tune will take advantage of it. I don't have E readily available near me, but I'll be running the DSX Flex kit. Who knows, for as much as I drive my car, maybe that will be my ritual. Drive to the nearest E85 pump, mix fuel, have fun, drive home.
