Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > ZL1 Parts
Old 06-24-2024, 12:08 PM   #1
Mike@SolerPerformanceLLC
Mike@SolerPerformanceLLC's Avatar
Drives: 2015 Corvette Stingray
Smile The Ultimate Acceleration | Soler Performance
Soler Performance
Premium Throttle Bodies | Absolute Throttle Control
Website: https://www.solerengineering.com/generalmotors
October Discount Code: TIFFSP
Emailtiffany@solerengineering.com
Call/text: (251) 468-9786
Premium Modified, Ported, and Calibrated Throttle Body.
FEATURES:
• Optimized Active Contours with sonic flow nozzles
• Porting Taper and Upstream Bore with Velocity Stack
• Greater Discharge Coefficient of Plate/Blade interface
• 16 Ra Microinch, Diamond Polished Surface Finish
• Shaftless high-pressure side of the blade for Larger WOT Flow Area (91 mm Effective Bore)
• Self-Cleaning Throat/Flow Gap
• Dome and Thread-locked Screws
• Dimpled shaft trailing edge
BENEFITS:
• Lower weight to power ratio at part throttle, for a more nimble/spirited driving experience
• Linearization and smoothing of the curve for a more predictable response and crisper shifts
• Immediate response right off idling while keeping idling function undisturbed (No Hesitation/Stumble)
• Does not require tuning. Warranty safe.
• More air/power at every single throttle position after idle. Crucial for starting or expanding power gain modifications
• Easy Installation
DLX Bluetooth Throttle Controller
The perfect match for our Throttle Bodies.
FEATURES:
-Dual control, directly on the display or remotely from your smart device.
-Ten Modes, with a total of 64 possible settings (see chart).
-Sturdy aluminum construction, buttons, and heavy-duty harness.
-Self-adjusting OLED display intensity for optimum visibility.
-Real-time throttle position gauge.
-Fail-safe vehicle-specific design.
-Does not require the display to operate, for those who prefer a fully concealed device.
BENEFITS:
-Controls pedal sensitivity, allowing the driver to adjust an otherwise widely considered non-linear (slow/spongy) pedal response/map.
-Increases the sensation of acceleration/power, very important for driving pleasure in finely tuned sports cars.
-Complements performance Throttle Bodies in achieving total throttle control as a system.
-Plug-and-play modification.
-Warranty safe modification.
-Easy installation (15 min, no tools or special skills required).
Last edited by Mike@SolerPerformanceLLC; 10-01-2024 at 04:45 PM. Reason: Updating discount code
Mike@SolerPerformanceLLC is offline   Reply With Quote
Old 06-24-2024, 12:21 PM   #2
Z OH 6
Drives: 2021 Red Hot ZL1
Never heard anything but great things about both of these products. I use the throttle controller on my ZL1 and love it.
Old 06-24-2024, 01:30 PM   #3
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
I decided to enliven my LT4 with the TB and Controller!
Old 06-24-2024, 01:34 PM   #4
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Love my 103
'20 ZL1 Black "Fury"
Old 06-24-2024, 01:55 PM   #5
Broooster
Drives: Sharkskin Metallic ZL1
Love the controller. The "LOCK" feature makes it worth it, even if you don't use anything else.
Broooster is offline   Reply With Quote
Old 06-24-2024, 02:33 PM   #6
Talking
That is great to hear!
Old 06-24-2024, 02:35 PM   #7
Definitely a great feature that makes it well worth it. Can never have too many theft deterrents on a vehicle. And also can't pass up the 10 modes with a total of 64 possible settings.
Old 06-24-2024, 02:36 PM   #8
Love my 103
Glad to hear that! Let me know if you're ever thinking about a throttle controller. Would love to help you out.
Old 06-24-2024, 02:40 PM   #9
Not only did you enliven it, but you got two components that work great with each other. You get the physical gains from the TB and the electrical gains from the TC.
Old 06-24-2024, 09:16 PM   #10
The Maverick
Somewhere in the Kalahari
The Maverick's Avatar
Checked out the manual but wanted to confirm:
The lock setting can only be toggled from the app and not turned on or off from the USB display panel?
Old 06-25-2024, 09:11 AM   #11
clg82
Drives: 2020 Camaro ZL1
Don't mean to derail this thread but just an FYI....if you're going to tune the car make absolutely sure you disconnect the throttle controller as the car will go into limp mode and do all kinds of weird things while tuning etc.
Old 06-25-2024, 10:34 AM   #12
Yes, that is correct. It is only accessible through the Bluetooth app.
Old 06-25-2024, 10:35 AM   #13
No worries. Yes, that is correct. If you plan to tune your vehicle completely remove the throttle controller before tuning. After tuning, the throttle controller can be reinstalled
Old 06-25-2024, 02:52 PM   #14
Rnovrit
Drives: 2018 NFG ZL1-1LE
I tried using the search function but it won't work. What size is our stock throttle body? (2018 zl1)I am looking to order the throttle body and controller. Car is completely stock. This will be the only mod. Car is primarily a weekend toy used for the occasional road course fun day.
Thanks
Rnovrit is offline   Reply With Quote
