![]() Drives: 2019 Camaro 1SS1LE Join Date: Jan 2024
ARP Hardware LT1
Just wanted to get a thread on this as both google and forum searches have produced few results. Mostly because the "LT1" key phrase gives so many non-Gen 5 results, hard to filter out in a google. Hope to get some feedback from others who have upgraded to ARP hardware, in case there's something I missed trying to figure out a few WTF moments.
I tried to upgrade as much fastener hardware as possible on my build, I've always been a fan of ARP on all my Ford builds, you could get virtually everything in ARP hardware and it works great, and of course, REUSABLE! I feel like ARP has really let down the Gen 5 LT's this time around. I order ARP Rocker Arm Studs, but can't use them with my CHE trunions. The hat on the nut is too wide to fit within the flat of the trunion. So for now, I'm going to re-use the OEM bolts. Also, the ARP Studs would not have fit the OEM trunions either. There are 4 dimples that make you kind of thread the bolts through the trunion, and onto the head. It is the same for the ARP studs, the rocker won't slide over the stud, it gets caught on the trunion dimples. You ~could~ thread the stud onto the rocker, and then install the stud with the rocker on to the head. But that's not right. And not how a stud should work. ((ARP actually told me to drill out my trunions to make them fit the stud... ))So no ARP studs for LT rockers? That's not what the package says! Also ordered ARP flywheel bolts. You can imagine my disappointment when I tried to put a socket on one. Of course later, I did find a post by oldman stating the same... wish I saw that post before I ordered them and tried to install. Again, package says 6.2 LT1 SBC. Yet, you can't use them. No method on earth, no modified tool exists. So ARP just made them and never actually applied them? I'll be on the phone with ARP today to talk refunds and criticize them, lol. If you can only use ARP hardware under specific circumstances, that's something they should disclose with the product and instructions. GM wins again, unfortunately. $90 for a set of flywheel bolts. No wonder share holders can't get enough of GM, lol.
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane 7/26/2024 Tuning in progress |
Thank you Al Oppenheiser!
Perhaps specific terms would be more useful ... gen5 is the engine, not the car.
https://www.google.com/search?q=arp+bolts+gen5+6.2 These guys apparently offer flexplate bolts (4th link from that query, no personal affiliation): https://www.michiganmotorsports.com/...astners/gen-5/ |
#3 | |
Also, to my understanding, flexplate bolts are not the same as flywheel bolts. I think flexplate bolts are shorter. Also, ARP specifically states not to use their flexplate bolts on a MT flywheel. Some day, I will have to replace my clutch/flywheel, and when I do, I will make sure I can move away from OE hardware. Stealership wants $14 per bolt, and I need 8 of them. Then they tell me they'll have to order them. RockAuto only wants $7 per bolt. And I can get them 2nd day for $27. Guess who got my money? But the industry likes to discontinue hardware, so the last thing I want is to be caught in that shitty trap. Hopefully there are normal flywheels/clutch kits in the aftermarket lol. Update, I did get in touch with ARP again this morning and they worked with me to find a nut that fits their rocker studs but has a smaller diameter flange. If it works out, they want pics to send to their team to push for kit options, as I am not the first person to contact them regarding issues with this stud kit. Won't help with drilling OEM trunions, but for the many running CHE's, it'll be nice to have the option for the smaller diameter nut flange. For the record, the nut flange will be slightly bigger than the OEM bolt flange, but within the CHE trunion's footprint. He said they advise keeping the kits torque spec and procedures, so nothing changes there. And he submitted a report for the flywheel bolts and said I wasn't alone in reporting non-fitment for the OE flywheel setup either. Hopefully we have a solution for the rocker studs, will be nice to utilize those. I'll be returning the flywheel bolts.
![]() ![]() Drives: 17 hyper blue 2SS M6 Join Date: Mar 2018
Guess I'm not the only one hundreds of wasted dollars into ARP hardware that doesn't fit... I have the flywheel bolts and the rocker studs sitting on the shelf
Well the flywheel bolts are going back to the vendor. If any legit ARP vendor has a problem taking them back, you can talk to ARP and they'll get you straightened out. Though, not sure if there is a window of opportunity there. As for the rocker studs, if these nuts from ARP work out, then there's a solution. As far as using them for OE, it's not possible without drilling the dimples off. I told ARP I don't see a drill bit being very accurate in that space, I think a dremel with a small grinding bit would be the safe way. But you gotta hit each rocker 4 times to flush it out. That's a lot of work to run studs on OEM trunions lol. At least the CHE's just need the smaller diameter flange nuts.
The Mechanic
Drives: 1SS M Join Date: Dec 2017
Same happened to me with the flywheel bolts, specifically labeled for gen 5 lt1 but doesnt fit any socket in the flywheel to tighten it because its about a 19 mm in a 19.5mm hole. Called arp and theyre useless, clearly haven't tried to actually fit these bolts or match oem.
BTR 225 w/CNC Heads|JLT intake|Speed Engineering 1"7/8 long tube and mid pipe|LT2 manifold w/95mmTb|Self tuned w/HPtuners|Silvers 2Way coilovers|Hotchkis front sway|Advan AD08R|BMR solid cradle bushings|Recaro SR7| Work ZR10 19"
#7 | |
