![]() ![]() ![]() ![]() ![]() Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
Can ptm cause brake fade?
I was on track yesterday. I have done a few track days but I am still a novice. I drive in sport 1. Reviewing my sessions when I got home I noticed I didn’t drive my best that day as ptm intervened a bunch around the hairpins. A couple of times I got what I thought was pad fade. I would back off for a lap and then the brakes would feel normal again. I am aware that ptm can use the rear brakes to help you keep the car strait. Could I have been overheating the rear brakes enough to give me what I thought was pad fade? I wasn’t sure if it was pad fade or fluid.
One other thing. For the final session I forgot to enter ptm. I had no brake fade on the final session. This is why I am wondering if it is possible to overheat the rear brakes enough to get a soft pedal a few times but I wasn’t sure if it was pad fade of boiled fluid. I did see the smallest amount of fluid seeping around 2 of my outside bleeders. This was not a situation where I had fluid all over my wheels. Just a tiny bit of seepage. Waited an hour for them to cool a bit and tightened them about 1/16 or 1/32 turn (didn’t want to go full Hercules here because last thing we all want is to strip a bleeder screw). I’m not sure if tightening the 2 screws fixed the brake fade or if not turning ptm on fixed the fade. Since most of the work is done by the front brakes I’m really not sure so was wondering if you guys could figure it out/answer it for me. Car only has 3k on it, one track day prior to yesterday, endless fluid and stock pad. Also have blackwing deflectors installed.
Current: 2023 2SS 1LE
Prior: 2016 Camaro 1SS 2007 Mustang GT 2008 Civic Si |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
Yeah, if nannies are regularly intervening I'd go to Sport 2 or Race.
![]() Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE Join Date: Feb 2020
You shouldn’t over heat the brakes or fluid with Endless. The PTM will definitely make the brakes run a bit hotter if you keep getting it to intervene. Did you smell your brake pads much?
#4 | |
I did smell my brakes 1 or 2 times that day. I asked someone this but I didn’t get a clear answer. Would braking longer but less hard create more heat than braking harder but for a shorter time? I definitely need to work on braking but part of it is due to losing confidence when I would get the further traveling pedal. I definitely am a culprit of braking longer and softer versus harder and shorter.
#5 | |
#6 | |
I’m gonna be honest I actually did spin out into the grass due too oversteer on corner exit. I was stunned because I didn’t feel like I did anything different. This was the 3rd session and there was a large gap between session 2 and 3. Originally I thought it was due to cold tires but the teachers watched my pdr video and said I gave too much gas in the middle of the corner. Personally from what I read on here I thought sport 1 would have saved me as it had been all day. Do you think sport 1 should have saved me and it could have been due to cold tires/hit something slippery? It was during the 3rd lap. Keep in mind it’s a very short track, approx 1 min with a good driver in our cars so that’s why I thought cold tires as I’ve read on here it takes about 2 laps for supercar 3’s to heat up on a normal length track. I don’t drive that hard during the first lap.
#7 | ||
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Responses in RED.
"KEEP THE FAITH"-Fbodfather |
#8 |
Thank you for the answers! I feel a lot better about it being pad fade versus boiling fluid. I did not know that if I boil the fluid I would never get a firm pedal back. I did stick a toothpick in the bleeders to get some residual fluid out but I must not have waited long enough for it to come out.
#9 | |
#10 | |
https://youtu.be/MIh3YZW0db4 Appreciate any advice I get from everyone.
#11 | |
![]() ![]() Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
Couple of things to fix it would be to open up the steering faster as you apply throttle. Car can only do so many things at once. If you want to be aggressive on the throttle you need to decrease steering angle. Otherwise be smoother on the throttle. |
#12 | ||
![]() ![]() ![]() Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
If you had kept throttle steady or reduced it slightly (by maybe 10-20%) you probably could have caught the slide instead of spinning but it takes work and practice to train yourself not to lift off of the gas pedal when you feel the back sliding. Also you should keep looking where you want to go during the slide which would be out the passenger side window in this case. EDIT: I wrote this before Christian1LE replied then dug up this video before posting. Here is a big slide I had on cold Supercar 3 tires in the second corner of my home track with traction and stability control fully disabled (no PTM). I had to apply 305° of countersteering in about 1 second to catch it. I lifted and braked during the slide otherwise it should have required less countersteer but I did that on purpose knowing there were tire walls on both sides of the track ahead and slowing down before I left the pavement improved my odds of not hitting them if I went off into the grass. I have previously seen someone hit one of those tire walls during an event I attended and I was passenger with an advanced driver who had oversteer in the same spot in his C7 Corvette but he overcorrected and we went backwards through the grass stopping just short of the tire wall. Last edited by cdrptrks; 06-25-2024 at 07:34 PM. |
#13 | |||
I downloaded the cosworth tool just now and looked at the data. The lap I spun which was lap 3 on a short track tire temps were between 99-104. I will try to be smoother from now on on really thought turns. Either less angle and a little more throttle or more steering angle and less throttle. I’ll keep all those things in mind when sliding (hopefully doesn’t happen again) about braking on pavement and looking where I want to go. I’ll also admit and I’m not ashamed to say this, it was kinda scary having it happen to me the first time in my life in real life. I drive on my racing sim/assetto corsa a lot and practice causing oversteer for fun/training and I am decent at catching it in that sim but if I mess up in the sim nothing bad happens whereas I was worried about possibly doing a 180 and facing oncoming traffic when it occurred in real life. Of course if there were walls I would have counter steered and hopefully remembered to apply throttle to save it.
#14 | |||
I downloaded the cosworth tool just now and looked at the data. The lap I spun which was lap 3 on a short track tire temps were between 99-104. I will try to be smoother from now on really tight turns. Either less angle and a little more throttle or more steering angle and less throttle. I’ll keep all those things in mind when sliding (hopefully doesn’t happen again) about braking on pavement and looking where I want to go. I’ll also admit and I’m not ashamed to say this, it was kinda scary having it happen to me the first time in my life in real life. I drive on my racing sim/assetto corsa a lot and practice causing oversteer for fun/training and I am decent at catching it in that sim but if I mess up in the sim nothing bad happens whereas I was worried about possibly doing a 180 and facing oncoming traffic when it occurred in real life. Of course if there were walls I would have counter steered and hopefully remembered to apply throttle to save it. After the spin of course I went into the pits for them to look at my car and talk to me. When I got back on track I put it in ptm dry. Holy crap does it intervene. At one point my instructor said I can probably put it back in sport 1. I still was a bit scarred so I didn’t do it right away but I did wind up putting it in sport 1 the last couple laps and was just really careful around the turn I spun at.
