Old 06-22-2024, 06:43 PM   #1
wang970305
Drives: 2021 Camaro 2SS
ticking from Longtube headers?
Just went FBO last month..
I think here is like a ticking sound from long tube headers?..I have heard that is just a normal sound of lth? Is that true?
I can hear it from the bottom of the car clearly when the car is in park, when driving on the road, I can barely hear it when I slightly hit on the throttle.
2021 Camaro 2SS Summit White
Kooks 1-7/8'' LTH with high flow cats, Corsa Catback Exhaust, Roto-Fab CAI, Ported LT2 IM, LT5 95mm TB, Lethal Garage Flex Fuel Sensor, Mishimoto catch can, AEM Wideband.
wang970305 is offline   Reply With Quote
Old 06-22-2024, 07:33 PM   #2
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Expansion and contraction noises are much more prevalent with headers vs factory exhaust “manifolds”. Headers are thinner wall and longer, making noises louder and more frequent, so it’s part and parcel of running them.
Old 06-23-2024, 03:45 PM   #3
GreyGhost702
Drives: 2019 Camaro 1SS1LE
"Ticking" is generally normal from LTH's. As Josh pointed out, the thin wall material transmits sound more readily than the OE style manifolds, which are much thicker. I've read that having them jet coated helps reduce under hood noise from the headers. Even high temp header paint. You could also heat wrap them, but I've read wrapping headers can accelerate wear.
I kind of prefer the mechanical sounds from the engine. Particularly noisy lifters (healthy lifters), and of course superchargers/turbos. You could always dull the LTH tick with supercharger hum...
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane
7/26/2024 Tuning in progress
GreyGhost702 is offline   Reply With Quote
Old 06-23-2024, 10:03 PM   #4
I second (third) that. The noise profile of my LT1 definitely changed with long tube headers, the ticking is much louder than before. With the new forged bottom end, I hear a bit of valve noise underl oad, too, nothing like a sewing machine, just a pleasant little chatter.
The sound my engine emits under boost is not exactly what I'd call "hum", though, it's more of a thunderous roar with a tiny bit of whine.
Old 06-24-2024, 09:46 AM   #5
GreyGhost702
They just don't make 'em whiney like they used to, LOL. At least Procharger never changes. I did straight cut gears on my '08 Mustang GT D1SC. I thought it was going to have more of a turbine whine but it just sounded like clatter. Don't know how else to describe it. The helicut gears are definitely the way to go. My current D1X will likely get the Royal Purple treatment. I had problems with the D1 on my Mustang, the head unit drank its own oil. The seals were *not* bad, wasted my time (money) sending it to a shop to have it pulled apart and put back together. So I did what many others were doing, and got away from ATI's proprietary whale oil and ran Royal Purple XPR 20w50. Changed that head unit immediately. It stopped eating oil, it ran super smooth, and even had a nicer sound. Still sounded like a box of rocks, but it was a smoother box of rocks. Never had issues with the D1 after that, performance or otherwise. I put 50,000 miles on that blower, about 40,000 was on 20w50. I talked to ATI about it at SEMA back in 2014 but they clutched pearls and practically ran me out of their area. It was blasphemy that I wasn't using their oil and may the car gods have mercy on me and all that jazz. I'm like... if you guys offered a warranty that lasted longer than spit on hot asphalt, maybe I'd give a shit what oil was in it. But since it's on me to keep it operational, I'm personally not a fan of moving mechanical parts running out of lubricant lol. Fun stuff.
Old 06-24-2024, 10:43 AM   #6
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
100% normal.
Spaceme1117 is offline   Reply With Quote
