Old 06-21-2024, 09:02 PM   #1
NG329
Drives: Chevrolet Camaro ZL1 1LE
Lost a Front Brake Pad Pin
Went to change Rotors and Pads yesterday and noticed that the pin that holds the pads in place with the 13mm nut was missing on the driver side caliper. Any of you track rats ever have one of these vibrate loose in the past?
It might be a good idea to start safety wiring things in the future.
NG329 is online now   Reply With Quote
Old 06-21-2024, 10:11 PM   #2
RoaringV8
Drives: 2017 HBM Camaro SS 1LE Camaro
Yes, this happened to me and I had to buy the whole kit as that's the only way I could find the right bolt. It also happened to me on the driver's side. I'm wondering if I just didn't tighten it enough.
RoaringV8 is offline   Reply With Quote
Old 06-22-2024, 01:27 AM   #3
eimarshall
eimarshall's Avatar
Drives: 2018 SS 1LE Hyperblue
Same. I found it backing out as i was coming off track. The bolt was nowhere to be seen. Ive got a couple spares one hand now. And torque appropriately.
eimarshall is offline   Reply With Quote
Old 06-22-2024, 11:31 AM   #4
N Camarolina
N Camarolina's Avatar
Drives: 2021 2SS 1LE
27 track days and no lots bolts or pins like you describe.
I'd hazard a guess you guys are under torquing during reassembly, but please let us know if you purposely selected a lower torque value or didn't measure it. Lately I've reduced it by a few ft/lbs in an attempt to ensure I don't round-off the bolt head (hard to get any socket arrangement to sit correctly on the bolt head given local obstructions) and would like to ensure my bolts/pins stay in place.
N Camarolina is offline   Reply With Quote
Old 06-22-2024, 01:37 PM   #5
cdb95z28
cdb95z28's Avatar
That bolt is to be threadlocked. GM#89021297. High temp, high strength threadlocker. I use the equivalent Permatex #27200
22lb ft.
I've never had an issue between my '14 SS 1LE and current '22 SS 1LE, 55+ track days.
"KEEP THE FAITH"-Fbodfather
Old 06-22-2024, 06:34 PM   #6
NG329
Thanks guys! I'm glad I'm not losing my mind.
Old 06-23-2024, 05:33 AM   #7
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
Never had any issue, 87 track days. I just make sure its torqued properly. No mention in the service manual about thread locker on the bridge bolt, but if yours's is coming off, why not.. Torque is 22 lb ft (J6M)
Mods: MSD, Headers, 95mm TB, high flow cats, full 3" exhaust, SPL, MCS 2-way remotes, sway bars, rear diff lock outs, Sparco racing seats, 6 point harness, CMS roll bar, Nine lives wing, 6" splitter, ACS canards.
www.youtube.com/@Racer_Mike87
Old 06-23-2024, 12:56 PM   #8
carguy55
carguy55's Avatar
This is for the SS 1LE, haven't checked to see if the ZL1 is different. No Loctite needed
Old 06-23-2024, 01:55 PM   #9
eimarshall
eimarshall's Avatar
Originally Posted by carguy55 View Post
This is for the SS 1LE, haven't checked to see if the ZL1 is different. Obviously #2 should say NUT
It is a bolt. The pin has a threaded hole on the end.
Old 06-23-2024, 07:00 PM   #10
carguy55
carguy55's Avatar
you are correct! I'm going back to sleep now
Old 06-26-2024, 10:36 AM   #11
Badmojo
aka BeastZL1
Badmojo's Avatar
I've never had one loosen up and I do not reapply Loctite. High temp Loctite is a better solution than safety wire. I do periodically replace the pins, bridge bolt/pin, and spring every 15-20 track days.
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
