Old 06-21-2024, 02:27 PM   #1
Johnny Camaro
Drives: 13 ZL1vert,19 ZL1 vert A10 10/24/18
Rear dif oil change convertible
Hi guys I want to change my rear dif oil (2019 ZL1 Vert) but as you guys know the convertibles have a different a dif then the coups.
So my question is do I still use the same oil ? Dexron LS gear oil GM 88862624 or do I need other oil?
At the same time having it on the lift already I want to do my transmission oil as well. I saw multiple vids on YT but most of them are ZL1 LE are those the same 10A Speed tranny as in a regular ZL1?
I also see some do some don't change out the filter what do you guys do?
One guy brought the temp up first by letting the motor run for a while before he poured in the oil is that something you guys did to? He also made a big point of perfectly leveling his ZL1 LE, isn't the car leveled enough on a 2 post lift?
Johnny Camaro is offline   Reply With Quote
Old 06-22-2024, 02:30 PM   #2
IMCWORTH
IMCWORTH's Avatar
Drives: 2023 Camaro Convertible ZL1 A10
My owners manual doesn't list a different oil for my convertible when i did mine I used the Dextron LS gear oil
IMCWORTH is offline   Reply With Quote
Old 06-22-2024, 02:32 PM   #3
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
10-4034 is what you need as shown above in IMCWORTH's post.
Old 06-22-2024, 02:47 PM   #4
Johnny Camaro
Thanks guys. Any feedback about my transmission?
Old 06-22-2024, 03:00 PM   #5
IMCWORTH
IMCWORTH's Avatar
This is from the manual
Old 06-22-2024, 03:06 PM   #6
IMCWORTH
IMCWORTH's Avatar
Here are some owners manuals
Old 06-22-2024, 04:18 PM   #7
Vigilante375
Drives: 2018 Camaro ZL1
The A10 is the exact same in all ZL1s. The video you saw is correct on how to correctly do it. You have to bring it up to a certain temp, check the level by trying to drain any fluid out.
I hate it that GM went this route but it is what it is.
