Old 06-21-2024, 11:40 AM   #1
paradigm
Drives: 2022 Camaro 1SS 1LE
Apex SM-10 wheels on 2022 Camaro SS 1LE
I installed Apex SM-10 wheels on my 2022 Camaro SS 1LE.
Fronts are 19x10 et 20 with 285/35/19 tires
Rears are 19x11 et 35 with 305/30/19 tires.
My concern is that the rear tires are 3% shorter than factory, so the speedo will read higher and the miles on the odometer will add up faster.
Should I be looking to change to 305/35/19 or 295/35/19 tires instead to get close to factory wheel diamater?
Also there is no TPMS, has anyone been able to disable TPMS or spoof the system on these cars?
paradigm is offline   Reply With Quote
Old 06-21-2024, 04:09 PM   #2
Tay
Drives: 1985 Oldsmobuick
Yes you should change to a 305/35/19.
Why did you not install TPMS sensors?
Tay is offline   Reply With Quote
