![]() Drives: 2019 Chevrolet Camaro SS Join Date: Apr 2021
Procharger MAF location
So i’m getting ready to redo my charge pipe and was looking up how i need to set the maf bung up. It was said that the maf needs to be on the side of the pipe, no lower than the halfway mark. So basically the MAF needs to be slightly higher than perfectly horizontal.
If that is what is specified by gm, why is procharger son the underside of the charge pipe? I know that the Cold Air Inductions kit had it on the side of the tube as well.
'19 Camaro SS | LT4 High Side and LT4 injectors | Fore Innovations Triple 525 In-tank pumps | Too High PSI Secondary Port injection | E85 | Holley Low Ram | BTR Stage 3 S/C Cam | Circle D 3600 Stall | Forged pistons and rods | D1X procharger, 3.5 pulley making 18-20 PSI
| Tags |
| maf, maf sensor, procharger, tuning |
