Old 06-12-2024, 02:50 PM   #1
Shawnqa800720
Shawnqa800720's Avatar
Drives: 2018 1SS
SPL suspension component reliability
I installed the full SPL suspension set on my SS at the same time as I installed the ZL1 1LE DSSVs. I am having trouble holding alignment and wanted to know if anyone else with the SPL parts have similar issues. They go really far out really fast. within a month I have gone from -3.0 camber in front to -3.8, and -2.6 in rear to -3.1 on one side. Caster, toe, and thrust also go out to similar magnitude.
I am curious if this is an artifact of having no play in the suspension (no rubber bushings) cause all road impacts to have a more dramatic effect than would be seen, or if this due to either a bad SPL lot or if others are seeing anything similar.
Thanks!
2018 Red Hot 1SS, GM lowering kit & 1LE Sway bar kit, ZL1 1LE solid rear cradle bushings, BMR sway bar end links, GM CAI w/tune, Pray ported IM, Mamo ported TB, VS Forged VS07 rims 20x11 & 20x10 w/ Michelin PS4S
Shawnqa800720 is offline   Reply With Quote
Old 06-12-2024, 03:19 PM   #2
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
i would talk to turner at spl parts hes a super good guy and knows his stuff but ive had a full spl parts kit on my ss for over 3 years no issues
do about one alignment a year unless i go off track or hit some really big ass curbs at the track and never had any issues
