![]() Drives: 20 SS 1LE lt2,lth,rotofab,patg tune Join Date: May 2023
High idle and slow rpm drop
I need some help I have a 2020 SS 1LE M6 lt2, stainless power lth with hiflows, oiled rotofab and a patg flex tune. Setup is about a year and a half old and it’s been running great but recently I’ve been having a small problem. When I’m driving around I’m about to come to a stop and I put the car and neutral the rpm’s stay at about 1000-1500 until I come to a complete stop. On some occasions it’s even stayed at 1500 rpm’s when I’m at a complete stop. I took the intake tube off and looked inside the throttle body and it looked very clean and I also washed and reoiled my come filter.. Im going to spray some throttle body cleaner in it to see if it helps but has anyone else ran into this problem or know what else I can check?
Since this is your first post, I would check out the threads here on headers melting portions of the wiring harness.
Your problem may be unrelated, but you want to make sure your wires are properly secured away from the heat. |
#3 | |
![]() Drives: 2024 LT1 Join Date: Feb 2024
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
What throttle body are you using?
GM Gen V Calibrator
#7 |
I checked from under the hood and it didn’t like like any wires were touching the headers but I’ll check under the car too.
#8 |
![]() Drives: 2018 NFG 2SS 1LE! Join Date: Jul 2018
Do you have Rev match turned on? I noticed my revs will hang similar to what you describe but if I turn it off it stops doing it. Never noticed it before my tune.
#9 | |
![]() Drives: 2020 Camaro SS 1LE | Satin Steel Join Date: Jan 2022
HCI | GPI SS3 | E85 | xxx whp \ xxx tq
#10 |
#11 | |
#12 |
I had a similar issue and it turned out to be a vacuum leak from my oil catch can. The can drain valve was accidently left open after I drained it and it caused a big vacuum leak. Good luck! Chasing down weird problems like this can be very frustrating.
#13 |
Sounds like a vacuum leak that you simply haven't found. Need to data log and see what the fuel trims look like.
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 1SS 6spd Join Date: Jan 2011
A "hanging fast idle" is nearly always an intake side air leak. Besides clamps, etc... be sure to check the torque on your LT2 IM- don't over tighten! Specs should be in inch/pounds. Not very tight at all. If you are unsure or don't have a good inch/pound torque wrench, take it to someone who does.
It should be an easy fix, but you can do more harm than good if you're unprepared.
| Tags |
| iac valve, rpm issues, throttle body |
