Old 06-06-2024, 02:46 PM   #1
Sales@Phastek
Sales@Phastek's Avatar
Drives: 2016 1SS, 2010 Camaro SS
Exclamation Hendrix Solid Rear Cradle Bushings
Hey All, Jason here from Phastek
Have you had a chance to check out the Hendrix Solid Cradle Bushings? These are truly a work of Art. If you haven't seen them, here they are below. These bushings will completely lock out the Cradle Movement that you get when launching or between gear shifts. We do offer the BMR Cradle Lockout as well that fits into the Factory Rubber Bushings to help reduce some of the deflection. But if you really want to get rid of the Cradle Movement, then check these out.
Sales@Phastek is offline   Reply With Quote
Old 06-07-2024, 09:50 AM   #2
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Is the install similar complexity to the BMR stuff or is it more like having to drop the whole cradle with the other aluminum bushings?
Old 06-07-2024, 10:17 AM   #3
Sales@Phastek
This install is more complex than the BMR Lockout Bushings, you are going to want to drop the cradle to get the factory bushing pressed out and the Hendrix bushing installed.
Old 06-07-2024, 10:36 AM   #4
Sales@Phastek
Here are some comments from Guys that have them installed from Facebook.
Old 06-07-2024, 12:49 PM   #5
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
Installing these isn't that hard and the small increase in NVH could be considered subjectively preferrable for a sports car, it connects your butt to the road a little more directly. It's somewhat similar to using camber plates up front and how that improves steering feel.
If you want a highway cruiser maybe not, but then I'd rather have a Caddy.
"Josh Talbot" in the comments posted above clearly has no clue what he's talking about.
Old 06-07-2024, 04:07 PM   #6
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
lol i always wanted a set of the gm ones but i got quoted like 8 hours of labor so i never did them pretty much have everything else i can do to my suspension done
Old 06-07-2024, 07:24 PM   #7
DaveC113
DaveC113's Avatar
An experienced tech could do it in 4 no problem. Took me and a friend 4-5 hours never having done the job, including fabricating a press.
Old 06-08-2024, 07:33 AM   #8
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
After looking at the install for the solid ones we went with the BMR lockout kit which I'm pretty happy with. But these look like a great upgrade for more serious racers
Mods: MSD, Headers, 95mm TB, high flow cats, full 3" exhaust, SPL, MCS 2-way remotes, sway bars, rear diff lock outs, Sparco racing seats, 6 point harness, CMS roll bar, Nine lives wing, 6" splitter, ACS canards.
www.youtube.com/@Racer_Mike87
Old 06-08-2024, 11:01 AM   #9
jlaudio11
jlaudio11's Avatar
Drives: Chevy Camaro
I’ve had mine since last year, the time involved in installing has kept me from getting them in.
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, et street r’s on racestar recluse wheels.
1.33 3.75 5.75@122.98 1/8 pb 9.04@141 1/4 pb technically
'94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, otr intake
jlaudio11 is offline   Reply With Quote
cradle bushings, hendrix engineering, phastek
