Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
Hey Team,
For those of you who have the IGLA system, I am interested in hearing your feedback. Do you like the system? Would you recommend it? Any issues? or, what else would you recommend in its place?
2022 M6 ZLE: GMS Stage.III KONG X.PORT Package + DMS Lid + GMS Rear Bumper Belly Pan + GMS Hood Bracket + GMS Flex Fuel Package + MONSTER Triple S Clutch + XDI.50% Injectors + CLICK FOR BUILD LIST or www.GRIFFIN-MOTORSPORTS.com = 915rwhp 850rwtq + E60 + 15psi
![]() Drives: 1987 IROC, 2020 ZL1 Join Date: Nov 2023
I got the IGLA system awhile ago and for what it provides. I'm quite happy with it.
I really like how that it just lets the car work as it came from the factory, remote start was a big thing for me that I knew I wanted to keep working(either from the Fob or the App). I really feel like unless someone comes by with a tow truck my car isn't going to go anywhere unless I want it to. Also for me the PIN isn't a pain to use, especially if it's configured to require a pin before driving. Though don't honestly think it is that bad either when it is set to inhibit start either. However I have to login into multiple systems a day for my work, so your thoughts might vary on this. Plus there is the option to also use the included Fobs for authorization, which makes the whole thing invisible when I tested using them. Though using the fobs comes with a reduction in security, ie if those stolen with your regular key then someone could potential drive off. That's why it's recommended if going to use them to not keep in the car, or your fob, and don't use them for service visits. Actually have the car in shop right now, and set a temp pin and show them how to enter it and drive the car. So if something happens know for sure that someone in the shop isn't doing good things. Could also completely disable system temporarily using service mode, but again there is a reduction in security doing that. Also don't use it alone if parking somewhere where I want even more security/deterrence, have some additional layers. I always have a OBD port lock on(just to slow them down), even though if they program a key not going to do any good. And also add a brake lock(which again might be enough for someone to walk away, and if not adds more time). Again things to add to time before they even can attempt to try and start the car. Figure that thieves may just give up before they get to even trying to start it. Currently planning on add the OBD block upgrade to disable the OBD port entirely if not authorized by IGLA, and possibly also a Compustar system(not to stop a thief but deter/slow them down) still haven't decided on this one. So have had no real issues, though if you have it set to stall the engine, and forgot to authorize it will end up with some codes that need to be cleared(they aren't real but just part of the process of how IGLA interfaces with the car's computers to prevent theft). Never really considered anything else as the system and what it did sold me. Plus seeing how many cars that have had it have been attempted to be stolen but haven't was a big plus, along with some of the additional modes like anti-carjacking that can be added. I live in a city where they are unknown so having that as an option was another factor. The price for sure isn't the cheapest. But nothing else I looked at the time did what it does and what I wanted, so other things fell by the way side pretty quickly. My biggest concern now is broken windows, and other damage from failed theft attempts(hence considering adding the Compustar), but better than worrying if the car is going to be gone completely. So to sum it all up, I would definitely recommend it. Hope this helps! |
![]() Drives: 2023 SGM Camaro 2SS 1LE 6M Join Date: Apr 2009
Did you end up getting IGLA installed?
Past Camaro rides
1997 Black Camaro Z28 A4 1999 Silver Camaro SS 6M 2002 White Camaro Z28 A4 |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
Oh, I've had mine since I got my ZL1, over a year. It adds maybe 3 seconds to starting the car normally.
Ask me any questions. But I will say, I wouldn't own another car without it. Only way they are getting my car is push it / tow / flatbed. And for that, I had a hardwired GPS tracker with set Geo fences around home, work, gym, etc. Car moves out of that and I'll get a text / email. 100% worth the price of install ($1200) for the peace of mind of not having to worry about kill switches, fuel / starter relay interrupts, throttle body lock outs, etc.
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
what i don't like about it is they splice into your stock harness They need to cut the wire and connect the Igla. I have decided not to install it and did other options which work great and am in the same situation where it would need to be towed or pushed to take it and it didnt cost me over $1200
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
I went with the Ampire WFS400 self-install version and think it's great. I also did some other stuff at the same time, and did not have to cut my harness to install. Works like IGLA- no code, no start.
Mods being installed- oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc. |
#7 | |
Petro-sexual
#8 |
fo'shizZL1
The cheaper one without RF stuff (I didn't want something that could be potentially hacked eventually)
https://www.ampire.de/WFS400-LIN.htm...00-LIN&p=59260
#9 | |
![]() ![]() Drives: 2020 SS 1LE Join Date: Aug 2020
Lastly, I see you're from the states. No issues with initial purchase or shipping? Feel free to respond her or thru DM. Thanks in advance! |
#10 | |
![]() Drives: 2018 Hyper Blue Metallic 2SS 1LE 6M Join Date: Nov 2024
I am interested in this info, too. Thanks |
#11 | |
fo'shizZL1
If I were to have just pulled apart the interior and spliced it in somewhere, it would have probably taken a day, with me taking my time and enjoying the process. That's the key, though. You need to put it somewhere deep in the interior where it's hard to get to- that takes time and some forethought. Lots of options, though. If you have any electrical experience, it's pretty straightforward from a difficulty standpoint. If it's your first-ever electrical project, you'll probably want to phone a friend. No issues with purchasing. Bought it just like anything else online, and when you go to purchase it does the currency conversion for you through the payment site they use. Shipping was only a few days. Surprisingly, no different than if I'd ordered it from within the US. Overall, it was the path I wanted to take. I'm a cheapa$$ and couldn't justify $1,200 for $50 (or less) worth of electrical components. Plus I never trust anyone with my toys except myself. I also didn't want fobs or phone compatibility or anything else that could open exposure. I just wanted to punch buttons in the car itself, nothing else. This was that solution for me. Been very happy with it so far (about a year I think). Works great! Enter the code, car starts. Don't enter the code or enter the wrong code, car won't start. Simple and effective. As I understand, this is actually the previous generation IGLA. They are/were all made by a company in Poland called SEO I believe. That may not be true anymore, but I think that's what I found when I did the research originally. Here's the website: https://www.seoelectronics.pl/en/products/seo-canblu/
#12 |
![]() Drives: 2023 2SS 1LE Join Date: Oct 2021
Great write-up Rob. A few questions, 1. Is it difficult to change the startup code? 2. If you take your car to a shop how do you deal with the code input?
2023 2SS 1LE Radiant Red, A10, PDR, Black Lugs, ACS Rock Guards, ACS ZL1 1LE Side Skirts
#13 | |
Thanks so much for the info! I too have additional anti-theft measures but believe this is well worth the time and investment. Making the purchase today! Thanks for the guidance! |
#14 | |
Once there, scroll halfway down and click the Video tab, you can watch a youtube video that explains it all. Be sure to turn on CC for English. |
