Had a hard time shifting into first the other day (M6)
So its a nice 75° day, and I am taking my car to get the tint redone on the front windshield due to some grainyness right in my line of sight.
I try to shift into first after starting her up and... I couldn't get it to go in! I have noticed that shifting into first is generally a little "tougher" than the other gears, but I thought this was par for the course as I have nothing to compare it to. However not being able to get it into first at all was a bit weird. After some jiggling and playing around it eventually went in and I was able to drive like normal, but this was a bit concerning in the moment. Is this to be expected? Or is this another item to potentially have added to my list when I get it to the dealership?
2024 2SS Camaro, Riverside Blue Metallic, NPP, F55, CF5, 5ZZ, VTU, S0O, 5KP, JF5, 2nd Gen GFX
![]() Drives: 2022 Wild Cherry ZL1 1LE Join Date: Mar 2021
I'm not speaking from experience, but I would personally not consider this normal, as it definitely doesn't sound right, so yes I would certainly have it checked.
![]() Geoff |
Roger that. I'm about one fill up away from being fully broken in, I'm at about 1350 miles right now, I was planning on doing the rear end juice and potentially the transmission juice, but I'll have the dealership check it out first.
Oh wow, I totally missed that your car is brand new! I haven't had any gear shifting issue in over 14k miles so far (knocking on wood!).
Geoff |
![]() Drives: 2023 Camaro 1SS 1LE 6MT Join Date: Nov 2023
That's what she said (Sorry.....)
I have a bit of trouble getting it into second when cold (only with ambient temp like around 10°C or less). Hopefully that's normal.. it kinda sounded like it was with these transmissions. Is this right, or should I also get mine checked? |
#6 | |
![]() Drives: 2023 Camaro 3LT RS Join Date: Aug 2019
#7 | |
#8 |
every manual car I have had this happens time to time. Its not just lined up. Move it around in other gears and then push back to first and it will slide right in
2022 1SS 1LE 6M in Riverside blue
Found exact build local- ETA 7/31/22 New ETA - 7/26, 7/30, 7/31, 8/1, 8/8, 8/15, 8/21, 8/28, 9/17 8/24. IT HAS ARRIVED at the dealer 8/25- It is in the Garage ACS ZL1 Sideskirts, 20% tint, CAI Intake |
#9 |
![]() ![]() ![]() ![]() Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
start the car with it in gear to eliminate that problem.
#10 |
You can't start the car with it in gear if you can't get it in gear. The real way is keeping it in first gear(or reverse) when you shut the car off. My car is always in one or the other when parked depending on the grade.
#11 | |
![]() Drives: Camaro Zl1 Join Date: Jun 2023
It is absolutely not normal ....Clearing the gear when the car is off and not being able to get it in gear once started or upon downshift/upshift are 2 completely different things. i'm just going to leave this right here.
Gm's dirty little secret. Go easy on your gear shifting guys tremec or no, the gearbox is made of glass, and the brakes made of sugar... Beware. Can you tell i'm bitter about the 5k brake job i just paid for? They didn't even put the good brake fluid in, i had to get it rebled. Also just want to mention Ford said the MT82 unable to shift into third was normal... Now there's lawsuits. Last edited by Thestormoverkrynn; 06-14-2024 at 02:17 AM. |
#12 |
![]() Drives: 2SS 1LE Join Date: Jul 2023
definitely pretty tough to get into 1st gear until the car is fully warmed up in my experience, esp at cooler temps. report back what the dealership says, but my guess is they will say it's normal.
2024 2SS 1LE | 6MT | Riverside Blue
1100 - Order submitted - 7/12/23 2000 - Order accepted - 8/22/23 Vehicle Built (per chevy chat bot) - 10/10/23 Window sticker available online - 11/4/23 Arrived at dealership - 11/10/23 |
