Old 05-29-2024, 03:21 PM   #1
Osbornsm
Drives: 2018 SS 1LE
Smile Yeti cooler in the trunk?
Hello afternoon all,
I'm shopping for a Yeti 35 cooler. Technically, it should fit in the Camaro trunk. but wanted to verify.
Anyone have one of these?
Thanks!
~ Sean
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si
Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8
Results: 470 hp / 447 tq
Osbornsm is offline   Reply With Quote
Old 05-30-2024, 08:32 AM   #2
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
I have a Yeti 20, and just fits in, based on the width of the top, maybe a couple inches on each side. The 35 is a few inches wider on top, so it may fit, but hopefully someone can give a solid answer. It will be tight.
hrpiii is offline   Reply With Quote
Old 05-30-2024, 09:02 AM   #3
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
I have a Yeti 35 and can confirm it DOES NOT fit. It's too wide by about 2-3 inches and no matter what way you try to squeeze it in, it won't fit. The top of the yeti 35 is too wide.
GM Gen V Calibrator
Old 05-30-2024, 11:53 AM   #4
Osbornsm
Drives: 2018 SS 1LE
Thank you kindly... Was afraid of that. Wanted a cooler for track days / camping.
Yeti makes a few options for other types... I'll keep shopping.
What do YOU use for track day water/food?
Old 05-30-2024, 12:24 PM   #5
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
Like most stuff, I'm sure it fits in the trunk just fine. Getting it into the trunk is the problem. How about by putting the seats down? That's the secondary access for the trunk.
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
Old 05-30-2024, 02:03 PM   #6
Camby
Camby's Avatar
Drives: 2023/2SS/1LE/RadiantRed/A10
Holey moley! A Yeti 24 is $250!? Y?
2023/2SS/1LE/Radiant-Red/A10/Sunroof/Copper-Free-Breaks/Navigation —— Order History: 6/17/22-1100, 3/7/23-3000, TPW-4/3/23, 4/4/23-3800, 4/8/23-Delivered
Camby is offline   Reply With Quote
Old 05-30-2024, 02:16 PM   #7
crazedmodder
Drives: 2023 Camaro 1SS 1LE
I just bought a small soft sided one from Costco for cheap. I wanted a hard sided one but so many were just on the cusp of fitting through the trunk opening I didn't want to risk it. I figured with a soft sided one I could finagle it if I had to. Went cheap because if I want a good cooler then I will get a full size one and not use my Camaro (e.g. if camping and needing to bring multiple days worth of stuff).
crazedmodder is offline   Reply With Quote
Old 05-30-2024, 02:53 PM   #8
Number 3
Hail to the King baby!
Number 3's Avatar
LOL, my wife won a Yeti cooler in a contest. WORST COOLER EVER!!! Latches are a joke, handles are a joke. Weight is a joke and worst of all? The lid doesn't stat open on it's own unless you hold it open.
But yeah! An awesome cooler for $300. But it was free so no complaints..................other than the lid doesn't stay open on it's own.
Old 05-30-2024, 03:19 PM   #9
Osbornsm
Drives: 2018 SS 1LE
I am open to viable alternatives which are not igloo $5 coolers.
Old 05-30-2024, 03:20 PM   #10
Osbornsm
Drives: 2018 SS 1LE
Sounded perfect,
Except they don't make the 20 anymore and it's replacement is taller for WINE bottles. *sigh
Old 05-30-2024, 07:06 PM   #11
Number 3
Number 3's Avatar
Yep, I always go back to the Coleman cooler I had for like 30 years. Didn’t keep ice from melting for two days but did do it for the 4 or 5 hours I actually needed it to.
Old 05-30-2024, 07:11 PM   #12
CHASLT1
Drives: 2021 Camaro LT1
[QUOTE=Osbornsm;11427796]Hello afternoon all,
Thanks!
~ Sean
My 45 Qrt Yeti would not fit in my trunk on my 2015 GT stang or the 2021 LT1.
But sure fits in a C6 or 7.
CHASLT1 is online now   Reply With Quote
Old 05-31-2024, 08:49 AM   #13
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
There is no way you'll get it past the front seats to even try that. But good idea lol
GM Gen V Calibrator
Old 05-31-2024, 10:44 AM   #14
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
RTIC coolers are a less expensive alternative.
