Old 05-28-2024, 10:10 AM   #1
kevint
Drives: 2013 1SS
Generic ECM/BCM reader for multiple makes
Hey,
The wife and I will be looking to purchase a third vehicle in the latter half of the year, and while we're not sure what make/model we'll choose, it'll likely be used and out of warranty, so I want to make sure I have some basic diagnostic tools in place. I have what I use for my Camaro, and my wife's Jeep is still within the warranty period so we can take that in for whatever as needed.
Can you all recommend a generic code reader for ECM/TCM and/or BCM? I found a bunch on Amazon but I'm not sure what to choose.
Thanks!
kevint is offline   Reply With Quote
Old 05-28-2024, 10:13 AM   #2
SlowLS1
SlowLS1's Avatar
Drives: 2010 Camaro SS , 2011 Colorado LS1
This is the one I am considering buying, and was discussed here yesterday with another User who has this unit.
https://www.amazon.com/gp/product/B0744B55QV/
Started with this Post...
https://www.camaro5.com/forums/showp...81&postcount=9
SlowLS1 is offline   Reply With Quote
Old 05-28-2024, 10:18 AM   #3
gtstorey
Drives: 2010 Camaro SS2,L99, LSA SC
I went with am Autel, but don't remember the actual model. Chose it since it seemed to be the best price on one to be able to connect an oscilloscope.
My other option was a TopDon.
gtstorey is offline   Reply With Quote
Old 05-28-2024, 11:22 AM   #4
silversleeper
Big Crow
silversleeper's Avatar
Drives: '13 ZL1
I posted before about a foxwell. I got it on sale on aliexpress. It does more than what I need at an affordable cost. I did pay for 3 more automotive brands at $80 each to download a more full scan as I needed to dig deeper than the typical under $100 scanners would do. It came with 1 brand already preloaded that you must specify when ordering. I looked into the others mentioned and they were either more expensive or I didn't need that much like O'scope abilities. I wanted to get something to be able to do factory flashes but you can't easily or cheaply get into OEM data bases partly because of theft implications and the scanners for that are very costly. It's a rabbit hole I wasted days on.
edit: https://www.foxwelldiag.com/products/foxwell-nt710 here is exactly what I got and have like it for a couple years, they may have some newer better value replacement now IDK
https://www.aliexpress.us/item/32568...2usa4itemAdapt $160 but do your own due research which seller you trust just like any online shopping using smaller sellers.
as OP asks, you don't need to even know each diagnostic code and what it means and how to fix it. Simply finding a code will indicate something isn't perfect. You might be able to just reset them and they never return. It's something that happens but you don't want to do that to a car you don't own and be aware it takes time for things to relearn ie pass smog tests if you reset anything. I doubt any dealer would let you plug in to the OBDII but if you did it quickly at the convenience store on a test drive it would be unknown and not harmful. I wouldn't say a damn thing tho upon returning about all the codes you found and they would be pissed, what did you DO to our car without our permission on a test drive.
silversleeper is offline   Reply With Quote
Old 05-28-2024, 02:46 PM   #5
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
Autel I have MP808.
chevy pilot is online now   Reply With Quote
Old 05-28-2024, 05:04 PM   #6
bsn
Drives: 2013 ZL1
I have a Foxwell NT809 and its pretty impressive for the price.
bsn is offline   Reply With Quote
Old 05-28-2024, 09:18 PM   #7
chevy pilot
TOPDON Artidiag PRO has also received good reviews.
Old 08-26-2024, 10:57 AM   #8
kevint
Drives: 2013 1SS
Just wanted to circle back. I ended up getting the Foxwell NT630 Plus. It's advertised as an ABS and SRS scanner, but it seems to do almost everything else. I like that it also reads OBD, ECM, TCM, and FPCM, and can push commands like ABS bleeding. As a bonus, it can display and record live data.
I gave it a test on my commute to work and it's cool to see what my sensors are seeing, even if I don't know what they all mean just yet. I don't have any codes, so I didn't get to test that. I noted my tire light is on (I know at least one of my sensors is dead), and this didn't pick it up but I'm not sure if TPMS is a separate system that this might not read. It's not urgent either way.
