Old 05-27-2024, 02:38 PM   #1
brokedad
Drives: 2017 Camaro ss
Emergency brake error
I have a 2017 Camaro SS with an Aero 15’’ brake conversion. With that conversion it eliminates the emergency brake. While cleaning the car I somehow activated the emergency brake and now have an error light along with a constant ding. I can’t be the only one who has done this. How do I reset this? Thanks in advance.
brokedad is offline   Reply With Quote
Old 05-28-2024, 10:59 AM   #2
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
I have no idea what's involved with that conversion, but my best first guess would be to disconnect the battery for a bit and try rebooting her. Good luck.
Ventmaster is offline   Reply With Quote
Old 05-28-2024, 12:33 PM   #3
olrocker
olrocker's Avatar
Drives: People crazy with my sexiness
Did you leave the emergency brake connectors at the axle disconnected? If so by pulling the switch the computer is looking for them and it’s not getting a return signal or current load on the circuit. You should be able to clear it by removing the battery ground for about 15 minutes. Just keep in mind this will happen any time you accidentally pull the switch.
Purchase order submitted on 6/23/23
Received and purchased 9/8/2023
2024 2SS 6MT coupe
Sharkskin/Light gray
Moonroof/Navi/NPP/Mag Ride/Red Brake Calipers
Gray painted split spoke wheels
Illuminated footwells/illuminated bowtie
olrocker is offline   Reply With Quote
Old 05-28-2024, 02:26 PM   #4
brokedad
I did try to clear the code with a scanner with no success. I’ll disconnect the battery and see. Thanks again
Old 05-31-2024, 06:23 PM   #5
brokedad
Just encase someone else does this. You will have to manually release the cable using the 1/4 inch socket as described in an above reply. Then you will have to push down the brake pedal and also push the emergency brake button down to let the computer think you have reset the brake cable as well. At that point you can erase the code and everything is back to normal. Once again thanks for the help.
