Old 05-27-2024, 10:54 AM   #1
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
Track alignment question
I had the car track aligned just after the repairs were made.
Now the car seems to have a "delay" while turning. My first instinct is that something is moving while turning. The front cradle was dropped during the repairs.
One thing that was brought up was the camber change.
It drives straight on the road, but doesnt feel confidence inspiring.
They will go over all the bolts tomorrow to make sure everything is tight.
Has anyone noticed odd steering after a track alignment?
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 05-27-2024, 12:03 PM   #2
khcoaching
khcoaching's Avatar
Drives: 2021 1SS 1LE
IMO, these cars are very sensitive to toe settings. What toe setting was used?
I went back to zero toe front and rear, while not best for tire wear, a much easier car to drive.
Ken
khcoaching is offline   Reply With Quote
Old 05-27-2024, 12:09 PM   #3
nighttowl
nighttowl's Avatar
Ken
I havent yet seen the report. The alignment shop was closed when I picked up the car.
I should be able to get it tomorrow and report back.
Old 05-27-2024, 12:37 PM   #4
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
More negative camber will increase tramlining and increase sensitivity to road texture & contours. So some change should be expected. Tires can have an impact on this.
If toe is excessive (in or out) then you could get some odd steering behavior.
Old 05-28-2024, 09:45 AM   #5
nighttowl
nighttowl's Avatar
This is the report for the alignment.
Let me know what you think.
Old 05-28-2024, 09:55 AM   #6
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Any idea on the before TOE measurements? If it was toed out and you got used to that and now it's inspec, that might account for how it feels to you now.
Old 05-28-2024, 02:38 PM   #7
nighttowl
nighttowl's Avatar
The front cradle was dropped before it went to the alignment shop.
It was whatever the car was delivered with, any before results they got would not be what it was driven with.
Right this second I would say my 4x4 tundra has better steering response and road feel.
At freeway speeds if you turn the wheel to the right a little than turn back straight it seems to delay between the turn and the car moving.
When the car comes back it feels like the car is bouncing left / right.
what has been done:
front engine / suspension cradle dropped, re-installed.
coilover top mounts turned 180
track alignment
