Old 05-20-2024, 12:20 PM   #1
Tal_S
Drives: 1SS 1LE
Track tire pressure (Nankang CRS)
Hey guys.
So far I've been using the OEM Goodyear SC3 around 34-36 PSI hot on track, which seems to have worked well given how well they wore and their supreb grip.
I just switched to Nankang CRS with the same OEM tire sizes on stock wheels, for the upcoming local time attack championship. I've used these tires on my previous car, a turbo GT86 which was running 255s, but it considerably lighter per mm of tread, and on that it seems to have liked around 35+-2 PSI front and rear.
Has anyone got any experience with the CRS? Or any idea on ideal hot pressures for that tire? Or perhaps similar tires to it such as A052s which behave quite similarly?
Thank you!
Tal_S is offline   Reply With Quote
Old 05-20-2024, 12:33 PM   #2
khcoaching
khcoaching's Avatar
Drives: 2021 1SS 1LE
On a much lighter car, we were pretty happy with 33psi hot.
Ken
khcoaching is offline   Reply With Quote
Old 05-20-2024, 12:34 PM   #3
VR Baron
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE
Originally Posted by Tal_S View Post
Hey guys.
Thank you!
For autocross I and others used about 35/36 hot. One used 33. We all have rollover into the arrows but just a little. The side walls are a bit softer than stones or falcons it seems. But they grip very well. Those are psi’s for 18-19” wheels and tires though. My alignment guy who road races says use 34/35 as well, at 37 they get greasy
VR Baron is offline   Reply With Quote
Old 05-20-2024, 02:30 PM   #4
Christian1LE
Drives: 2004 BMW 330CI, 2022 1SS 1LE
For all my time attack events I run all my tire pressures as low as possible. I start them at 20psi cold, same for any other tire.
Not sure what type of time attack event you are running but as long as you can get heat into them before your hot lap then I would personally go really low. If you are running something similar to autocross then I would go up in pressures(I would personally start with 27 and play around from there). I ran my CRS V2's at 21psi cold for time attack event at CMP and they worked well.
Christian1LE is offline   Reply With Quote
Old 05-21-2024, 11:07 AM   #5
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
Wow that is LOW.... What kind of hot pressures were you seeing when you came off track?
IG: @NC_M1SS1LE
Old 05-21-2024, 11:46 AM   #6
Christian1LE
anywhere from 25-29 for Hoosier A7's but I only do 2 flying laps.
