Old 05-19-2024, 11:58 PM   #1
BeauRichardson
Drives: 2019 Chevrolet Camaro SS
Procharger IAT’s
Anyone close to maxing out their D1x? i’ve talked to the tuner about it and he wants to try either going air to water or putting some nitrous in-line with the procharger to help cool down the air and obviously get some more power. we would really like to make 1k wheel. We also discussed a meth kit but he isn’t a big fan of meth because if anything goes wrong it could be catastrophic. at least with nitrous we know what we’re getting into. The main issue right now is just how hot the temps are, i can’t remember at this moment, but it’s hot enough to cause pre det and pull timing.
'19 Camaro SS | LT4 High Side and LT4 injectors | Fore Innovations Triple 525 In-tank pumps | Too High PSI Secondary Port injection | E85 | Holley Low Ram | BTR Stage 3 S/C Cam | Circle D 3600 Stall | Forged pistons and rods | D1X procharger, 3.5 pulley making 18-20 PSI
BeauRichardson is offline   Reply With Quote
Old 05-20-2024, 08:46 AM   #2
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
What are the temps? Is it actually showing knock in the log or just pulling timing due to reaching a specific IAT temperature?
Old 05-20-2024, 12:41 PM   #3
rcoe
rcoe's Avatar
Drives: 2016 Camaro SS
With my tune I primarily use meth for cooling. And you can see in the log right when the meth kicks in as the IAT's definitely go down.
2016 Camaro 2SS 759whp 686wtq tuned by KingLt1
Procharger D1SC - Forged internals
BTR stage 3 cam - Circle Stage 3 trans
American Racing headers - Borla S-type
rcoe is offline   Reply With Quote
Old 05-20-2024, 04:05 PM   #4
BeauRichardson
as soon as i get to my computer i can check and see what the temps are. But it should just be showing knock. we have it set up to read when knock retard occurs, and the CEL does the blinking thing until it sits for a second which if i’m not mistaken is a symptom of knock
Old 05-20-2024, 04:08 PM   #5
BeauRichardson
What pulley are you running and what psi do you see? i think the main reason my guy wants to go with nitrous is because we’re maxed out on blower rpm, but still want to make a good bit more power
Old 05-20-2024, 04:25 PM   #6
jlaudio11
jlaudio11's Avatar
Drives: Chevy Camaro
Nitrous is good for making power. Not that great at absorbing heat to cool intake charge. If you’re trying to make x amount of power without spinning the blower to a point it’s just pumping heat it makes sense. If you’re not going to slow the blower down nitrous could just make the situation worse.
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, et street r’s on racestar recluse wheels.
1.33 3.75 5.75@122.98 1/8 pb 9.04@141 1/4 pb technically
'94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, otr intake
jlaudio11 is offline   Reply With Quote
Old 05-20-2024, 06:45 PM   #7
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I went down this road with my old 2.9 Whipple…if your blower is out of steam it’s time for a better blower that will operate at your desired airflow level in a much better efficiency island on the compressor map. I gained 104 WHP using the same pulley combo just by changing the blower to the new 3.0 Whipple. Band aids just don’t cut it in my humble opinion and you’ll be kicking yourself down the road for not just upgrading right now.
Old 05-21-2024, 07:55 AM   #8
KingLT1
KingLT1's Avatar
Centri's are different my friend. The Air to Air intercoolers are not as effective at keeping temps from increasing during a pull but they are better at cooling down after a pull. Hence why many use Meth kits to cool the intake charge on a Centri. Rcoe is a good example, I retuned the car to only rely on the meth for cooling. If it fails, the IAT would increase, and it will just pull timing, but the AFR is still safe. Using it that way, the temps are around 40-50 degrees cooler if I remember correctly. Another option is an ICE tank, but that isn't very convenient for the street. The Air to Air craze that Procharger touted for years when competing against Vortech was marketing. Yes it's convenient, no it's the most efficient way to keep temps down. Especially today with the power cars make.
A friends built H/C P1x car is making 822whp @ 14psi and it doesn't knock on E50 with IAT pushing 165. I have 22-23 degrees of timing in it. But then again if the OP has the same size race intercooler, the bigger supercharger is going to produce hotter IAT's pushing another 170whp. With the PD stuff, the IC bricks are also upgraded. I believe the 3.0 has larger bricks than the 2.9.
Moral of the story, Liquid cooling is better at keeping temps down during a hard pull, Air to Air has better recovery time post pull.
Old 05-21-2024, 08:42 AM   #9
18.2SS.1LE
18.2SS.1LE's Avatar
Drives: Chevrolet Camaro
Getting detonation and trusting the knock sensors to save the motor is going to break something.
Procharger P1X, CSP Big Boy Cam, CSP Headers, LT5 Throttle Body, MSD Intake, LT4 HPFP, LT4 Injectors, JMS BAP, 93 + Boostane - 750+WHP
18.2SS.1LE is offline   Reply With Quote
Old 05-21-2024, 09:07 AM   #10
Joshinator99
Moderator
Thanks King
Old 05-21-2024, 10:07 AM   #11
KingLT1
KingLT1's Avatar
FWIW GM setup the LT1 and LT4's along with many other ICE engines to live off the knock sensors. They are literally way over timed from the factory. In the very most optimal conditions you may see commanded timing the rest of the time they are constantly showing KR. The reason why they don't blow up is because the knock sensors and ECM's logic has a much faster response time.
Now the kicker is, if your tuner goes into the tune and starts messing with all that shit by decreasing sensitivity, max retard, zero out burst knock, then you for sure don't want to be seeing any knock in the tune.
Old 05-21-2024, 10:27 AM   #12
18.2SS.1LE
18.2SS.1LE's Avatar
I know they live that way stock, but at over 900 whp I don't think I'd want to be seeing any. I would imagine sensitivity is decreased for false knock from headers and whatever else could be causing some noise in that frequency. For it to detect knock, the engine still has to knock first.
Old 05-21-2024, 07:27 PM   #13
KingLT1
KingLT1's Avatar
agree!!
Old 06-04-2024, 08:29 AM   #14
BeauRichardson
Sorry for the late reply, i have been busy as it gets! but i believe there is some desensitization but my tuner told me he doesn’t feel comfortable taking anymore out. He still wants to maintain a pretty solid safety net. We are both learning the tuning aspect together. How funny of us to wanna learn on an lt. But so far things have seemed to pretty good. We’d like to get it on a dyno but that isn’t an option for us currently. But the air to air intercooler sucks in my opinion. which is why i will soon be purchasing the air to water brick that’ll sit on my intake manifold. Currently i’m pushing 17.8 psi out of the d1x and man it is getting hot.
I don’t really wanna be dealing with meth though cause i’d rather just fill a nitrous bottle cause i have a local guy who sells it. That’s where the idea of just running nitrous with the blower came into play but we haven’t really discussed it much further than that.
If i did do that would you suggest a wet or dry kit? And would i just tap it into the charge pipe before the maf of what?
cammed, iat, methanol, nitrous, procharger
